Old 09-20-2012, 08:11 PM   #1
Weird Power Supply issue
I bought a 120 volt switched power strip/ supply similar to what you would find for a desktop computer, that turns on various equipment independently. The weird thing is when all the switches are off the outlets are supplying 12 volts.
tyhorstman is offline   Reply With Quote
Old 09-20-2012, 09:02 PM   #2
Semi-Pro Electro-Geek
What are you measuring it with? If it's a high impedance digital meter, then you're reading "phantom voltage" that is capacitively and inductively coupled when the switch is off. It's not "really" there. Plug something into the power strip and measure again.
mpoulton is offline   Reply With Quote
Old 09-20-2012, 09:19 PM   #3
I measured it with a fluke 77-4 meter, I forgot about the possibility of phantom voltage, I'm not where the power supply is but I'll check it with something plugged into it when I can.
Weird water supply issue?? Speckert Plumbing 3 10-15-2010 12:22 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
Is 1000 watt power supply unit safe on home socket? darsunt Electrical 11 07-13-2009 10:41 PM
New dishwasher needs power supply. lupien Electrical 8 01-16-2009 09:58 PM
Need a new power supply Alan PC Repairs & Upgrades 18 06-15-2007 01:57 AM
