Old 03-01-2012, 07:48 PM   #1
Weird Pool wiring problem
Howdy. I bought a A O Smith a/c motor 3/4 hp on ebay which was new. Everything as described. I swaped the pool pump from my bad motor (bad bearings) to this one, I rewired it for 230V (came wired for 115V but can work with 230V), hooked it up, then nothing... No movement, noise, nothing... I checked that I'm getting 230V to the motor, but when connected I get 120V between white and copper, 120 V beetween black and copper but 0V between black and white (which are connected on 1 and 6 as the diagram shows), whereas when the motor is not connected I get 230V as I should. I'm thinking the capacitor might be bad. Any information you have sharing your experience would be helpful. thanks in advance
Ebay link from my purchase with pictures showing diagram and specs
http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_2399wt_922
nsxtasy is offline   Reply With Quote
Old 03-01-2012, 07:51 PM   #2
Sounds like your white and black are being fed from the same bus bar. Check where the two-pole breaker is feeding them in the panel to make sure you are drawing each from different bus bars.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
brric (03-01-2012)
Old 03-01-2012, 08:07 PM   #3
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Sounds like a bad connection that is causing you to lose voltage when there is a load?
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
nsxtasy (03-02-2012)
Old 03-01-2012, 09:14 PM   #4
The zero V reading is measured with the motor attached and power on but no load (no humming or anything like this). Would I still measure 230V (motor disconnected) if was indeed fed from same bus?
Old 03-01-2012, 09:19 PM   #5
no...
zappa is offline   Reply With Quote
Old 03-01-2012, 09:22 PM   #6
What sort of device switches power to the motor?
The Following User Says Thank You to zappa For This Useful Post:
mpoulton (03-01-2012)
Old 03-01-2012, 10:06 PM   #7
Semi-Pro Electro-Geek
Either both of your wires are fed from the same bus or one of the wires is not connected, which will cause the same symptoms. This could be a problem with a double-pole switch or contactor, or it could be a loose connection or wiring error. I must say though, swimming pool wiring is quite specialized and doing it right is extremely important for safety. This problem is quite basic, and it concerns me that you're working on pool wiring without the understanding needed to handle this sort of troubleshooting.
Edit: Having read 240V at the motor leads with no load connected, it's safe to say the wires on are the right busses. The only likely problem is a loose connection or bad switch/contactor.
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
brric (03-01-2012)
Old 03-01-2012, 10:16 PM   #8
rrolleston's Avatar
Don't pool's also require a GFCI? I know my parents pool stuff is on GFCI.
Old 03-01-2012, 11:07 PM   #9
" Euro " electrician
frenchelectrican's Avatar
They do required it and it will be well stated in Art 680 IIRC that will cover pretty well.
BTW that do count for both 120 and 240 volts motours.
I have one pool I dealt with one of my customer they have triphase pump motour and it allready on the RCD ( GFCI ) per French Nomes ( French Codes )
Merci,
Marc
Old 03-02-2012, 05:28 AM   #10
mpoulton....you have always impressed me with your knowledge and good advice on this forum, but you have left me scratching my head on this one. If you have 2 hots on the same bus how does one come up with a 240 volt reading, loaded or unloaded? Name:  blink.gif
Besides, the OP is replacing a motor with bad bearings in an obviously working system so what are the chances that he would go into the panel or anywhere else and switch wires around.
Old 03-02-2012, 06:09 AM   #11
Originally Posted by zappa View Post
mpoulton....you have always impressed me with your knowledge and good advice on this forum, but you have left me scratching my head on this one. If you have 2 hots on the same bus how does one come up with a 240 volt reading, loaded or unloaded? Attachment 46829
You're right. I didn't read carefully enough - I was assuming he hadn't actually measured 240V at the motor. The only explanation that's consistent with all his measurements is a very high resistance (defective) switch or loose connection.
Old 03-02-2012, 06:12 AM   #12
The capacitor won't be your problem. I would start by checking whatever it is that switches power to the motor. With the motor hooked up and turned on meter across the input and output contacts of your switching device on each leg. If working properly you should see essentially zero volts. A high voltage reading would indicate that the contacts are not making a proper connection. But if the system was working before I'm a bit confused as to why this power problem would show up now.
Murphy?
edit... sorry mpoulton, I was writing when you posted. Yes, a loose connection anywhere in the system also.
Old 03-02-2012, 11:50 AM   #13
J. V.'s Avatar
I would check to see if the motor has a switch inside the connection box that must be set for the voltage. OP. Whats the AO Smith model and serial number.
Old 03-02-2012, 01:25 PM   #14
It s à on/off outdoor switch with waterproof cover that uses 2 lines + copper line. Even when I'm measuring 0 V between lines at the motor, I'm measuring 230v at the switch when in Off position. Even when I'm measuring 0 V between lines , I'm still measuring 115V at between each line and copper wire.
Old 03-02-2012, 01:30 PM   #15
Murphy?
I am measuring between the 1 and 6 legs where black line and white line attach to the motor. This is Where I am measuring 0 V. So you're saying its normal?. So Why is the motor not spinning?
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 07:56 PM
Ontario Canada Pool Pump Wiring cramar Electrical 1 05-18-2011 05:58 PM
Wiring a pool Pleesehelpme Electrical 14 05-15-2011 08:21 AM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 09:49 PM
Problem with wiring (really long post sorry) okacookie Electrical 10 04-21-2009 09:54 AM
