Old 02-28-2012, 05:23 PM   #1
Exclamation
Weird lighting question??
So I have been googling everywhere but noone seems to have done this??
My problem is i bought 4 lights i want to install in the ceiling in my bedroom. Right now there is a light switch in the room that controls an outlet.
My question is how do I add a line from the switch, and route it up to the ceiling to connect to the lights? My main concern is I don't know how to add the feeder line or whatever it's called from the switch box. The ceiling does not have any existing wiring.
Thanks for any electricians help! I know this is probably super easy for you guys but i am a noob
federer is offline   Reply With Quote
Old 02-28-2012, 05:28 PM   #2
Do you want the existing switch that controls the outlet to control the four new lights?
Do you want the existing switch that controls the outlet to continue to control the outlet?
The outlet that the existing switch controls is it a duplex outlet?
If so Does the existing switch control both top and bottom of the duplex?
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
federer (02-28-2012)
Old 02-28-2012, 05:33 PM   #3
if it helps here is a pic. the light switch is left corner and the outlet has a lamp plugged into it currently.
Old 02-28-2012, 05:34 PM   #4
thank you for your help!
no i just want the switch to control the new lights. the outlet does not need to remain connected to the switch. i dont know what a duplex outlet is? how do i tell? thanks!
Old 02-28-2012, 05:36 PM   #5
here is the light i got. pretty neat!
Old 02-28-2012, 05:42 PM   #6
Turn off the breaker that feeds this outlet (which by the way is a duplex outlet). Then remove the switch from the box in the wall ( don't remove any wires from the switch) and let us know what wires are connected to the switch and if there are any other wires in the box.
daveb1 is offline   Reply With Quote
Old 02-28-2012, 05:44 PM   #7
how do you know its a duplex? thanks let me go open up the switch
Old 02-28-2012, 05:52 PM   #8
Electrical Contractor
A duplex is just what it sounds like, 2.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
jbfan is online now   Reply With Quote
Old 02-28-2012, 06:00 PM   #9
oh lol i am stupid
Old 02-28-2012, 06:01 PM   #10
ok so like an idiot i open up the box without turning off the breaker. the thing goes "SPARK' on me and now the switch is toast anyways here is the pic i got
looks normal to me. basically my question is how do i add a feeder line from this switch up into the ceiling ???
Old 02-28-2012, 06:02 PM   #11
The 'light' you pictured is just a trim, you do have the correct housings as well, correct?
Techy is offline   Reply With Quote
Old 02-28-2012, 06:02 PM   #12
Simple. Turn off power. Fish a piece of 14/2 or 12/2 from the switch to the lights. When the wires are run, we can help you with the connections. Do you have access to the attic?
hawkeye11 is offline   Reply With Quote
Old 02-28-2012, 06:04 PM   #13
The bad news is you do not have enough room to add another cable.
I bet the breaker tripped and did not mess up the switch.
another pic stright into the box will help.
Old 02-28-2012, 06:08 PM   #14
Smile
first thank you guys so much. this place is such a community!
techy-my concern is with adding the feeder. the light fixture i got it taken care of.
hawkeye-thats precisely my question! how do i fish a new piece of the wire from the switch? do i just buy a new line and twist it to the switch wire that's existing??? i know how to make the connections once i havethe wire in place. sorry i wasnt clear before
jbfan-let me go down and check on the breaker to see if it tripped. thanks!
oh the ceiling is already open so easy access. at the ceiling anyways. the wall is closed though
Old 02-28-2012, 06:11 PM   #15
here is the ceiling where its going. 4 lights total. i need to add junction boxes to house the lights
Question about lighting circuit Alan Electrical 5 01-29-2012 09:53 PM
First post, weird question jackobear General Discussion 13 11-04-2011 05:03 PM
Shower lighting question. ingeborgdot Remodeling 3 05-19-2011 07:57 PM
Recessed Lighting Noob Install Question?? help! windycitystyle Electrical 1 01-20-2010 12:53 PM
Question about outdoor lighting LAFORD1986 Electrical 3 01-03-2010 10:26 AM
