-   -   Weird light problem..please help. (http://www.diychatroom.com/f18/weird-light-problem-please-help-15178/)
Tracie 01-04-2008 05:06 PM
Hi. I have a light in my stairway which I can usually switch on/off at the bottom or top of the stairs, however, yesterday it went all weird! Eg..If I turn it on at the bottom of the stairs I now cant turn it off at the top but if I go back downstairs and turn it off down there I can go back upstairs (in the dark) and turn it on and off up there...its all very strange! Is it dangerous to be like this and should I urgently get an electricial out to have a look?
bigMikeB 01-04-2008 05:19 PM
You have a bad switch, it isn't wierd just broken.
Tracie 01-04-2008 05:24 PM
Thanks for the reply. Can it really be broken tho if it works? Depending on what position the one switch is at depends whether the other will? Not that I am doubting your knowledge but im not sure that i explained the problem properly.
220/221 01-04-2008 05:29 PM
If has always worked properly and no one has messed with it, it may be simply a bad switch or loose wire at the switch. It is not likely a dangerous thing unless you fall down the stairs because it's dark.....unless it's a loose wire, then it can arc and eventually cause more serious problems.
It may be a DIY repair. Get 2 new 3way switches, turn OFF the power, remove switches. You will see THREE wires attached to the switch. Take note of the COMMON wire. It is marked on the old and new switches as "common" and has a darker colored screw. As long as you get the COMMON wire hooked up to the right terminal, you will be good.
For a temp repair, try roughly turning the switch on and off several times to unstick it.
