Weird Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 05:45 PM   #1
Weird light problem
The lights in 3 of my bedrooms, bathroom, and kitchen plugs will not come on unless i turn on my clothes dyer. Anyone know why and how to fix it?
stephdec1984 is offline   Reply With Quote
Old 08-04-2012, 06:32 PM   #2
Mad Scientist
You've lost one leg of your incoming service. Step one is to try turning your main breaker off and then on. Step two is to call the power company and have them check their connections.
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
stickboy1375 (08-04-2012)
Old 08-04-2012, 06:47 PM   #3
Wow, that's a weird one alright. It sounds like the power passes through the outlet ONLY when the dryer is running. The first thing I would do is trip the breaker and pull the dryer outlet and see what's going on in there.
I'm sure people with more experience will respond also, but it seams strange to me that the dryer is sharing a circuit with so many other outlets.
dadtorex is offline   Reply With Quote
Old 08-04-2012, 06:51 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Its not, when the dryer is running the 240v heater is completing the circuit path, same thing happens with an electric water heater and you lose a leg.
Old 08-04-2012, 06:52 PM   #5
Mad Scientist
What's happening is this:
Your incoming electrical service is made up of two 120V lines, 180 degrees out of phase with each other so you have 240V between them.
One of the 120V lines has gone dead, probably due to a loose connection or broken wire.
When the dryer (A 240V appliance) is turned on, power is going from the good 120V leg, through the dryer's heating element, to the bad 120V leg.
All the circuits one the bad 120V leg are only getting power when it is fed through a 240V load such as the dryer. You'll find that none of your 240V appliances will work properly, and every other circuit breaker in the panel is dead.
It's easy to verify with a meter, if you like. You simply remove the circuit breaker panel cover, and carefully measure voltage at the terminals where the service wires connect to the main breaker. Normally, you would have 120V between each terminal and ground, and 240V between the two terminals.
I expect you'll find that you have 120V to ground on one terminal, 0V to ground on the other, and 0V between them, except when a 240V appliance is on.
Old 08-04-2012, 07:45 PM   #6
I think you're right because when I put the charge indicator on the dryer outlet it lite up 120. I tried flipping the main breaker off and then back on but it didn't help. Any more suggestions?
Old 08-04-2012, 07:45 PM   #7
E2 Electrician
Call your power company... or just do more laundry.
Old 08-04-2012, 08:41 PM   #8
Missouri Bound's Avatar
When you turn on your clothes dryer....it doesn't work very well, does it?
Do you want it your way or the right way?
Old 08-05-2012, 01:06 AM   #9
Talking
To mcsteve
Thank you so much for your advice. I called the electric company and they sent out a tech who said exactly what you said and fixed it. You're a blessing to me and my family. Thank You.
Old 08-05-2012, 01:22 AM   #10
Master Electrician
Hey someone actually listened to the advice they got and low and behold a sucess story.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
oh'mike (08-05-2012)
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Snowblower light problem. honeyboy 18 Landscaping & Lawn Care 7 01-20-2011 08:19 PM
Three-way light switch problem tripower Electrical 10 01-15-2011 11:07 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Problem Wiring A Porch Light AuD14 Electrical 5 10-31-2010 11:09 PM
