Weird Breaker Blow - Electrical - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 02:49 PM   #1
Rewards Points: 81
Weird breaker blow
I have been out of the area for a few days and I came back to my shop to find the power out in multiple areas in the building. The odd thing is the circuits that blew are seemingly random. There is a two pole circuit breaker where the only thing on it is 6 T5 lights and 4 outlets with nothing plugged into them. That circuit breaker blew. Also, I had 2 sub panels installed. The right side breakers are all dead, but the left side breakers all work just fine. The 6 gauge wires supplying the sub-panels are plugged into the same dual pole 30 amp breakers. One breaker for one panel, and the other for the other panel. I test the wires right at the breaker and one wire has juice and the other does not.
Has anybody ever seen anything like this? WTH happened? Im can usually do my own small power projects but this seems unusual.
tunaman is offline   Reply With Quote
Old 10-09-2013, 02:55 PM   #2
joed's Avatar
Rewards Points: 12,918
Are the breakers actually tripped or is there no power from them?
It sounds to me like one of the hot lines coming into your building is out and you only have 120 volt service right now.
Is the shop fed from the POCO or from another building?
Old 10-09-2013, 03:18 PM   #3
Rewards Points: 81
Ah, so I just checked and it does look like that is the case. That I am running in 110v mode and that one of my supply lines is knocked out. I just tested the supply lines themselves and sure enough, one is showing 116v and the other is showing 0.
The main panel in my building I believe is a subpanel. There is a 500amp breaker in the main building and if I turn that off I lose power along with a few other things. I am not sure what lies between that 500amp breaker and my main panel. I just emailed my landlord to find out.
Old 10-09-2013, 03:51 PM   #4
Rewards Points: 81
I just went and looked at the power wall and it looks like there is a box of 100amp breakers but none of them are labeled except for one. The name of which leads me to believe this is the right panel. However,none of the breakers are tripped. They are all in the On position though.
Old 10-09-2013, 06:16 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,366
If it's a rental property! then you might have to leave it to the landlord and electrician to fix !
Some circuit breakers can be tripped but still look to be ok,
You might try to turn each breaker off,
Wait a second or two,
Then turn back on again !
You could disrupt power to others,
so do it at a time when it's least likely to cause problems,
Or speak to your neighbours first !
P.S. When you know whats what, then label the breakers !
It will save you trouble in the future.
dmxtothemax is online now   Reply With Quote
Old 10-09-2013, 06:50 PM   #6
Rewards Points: 81
Yeah, I am a tenant but also the groundskeeper. Im going to try flipping switches later tonight after everybody has gone home. Im hoping it works.
Ryan
Old 10-09-2013, 07:03 PM   #7
If you have a non contact tester,
Maybe you can check for power on the load side of the breakers.
But be careful !
Old 10-09-2013, 07:12 PM   #8
Rewards Points: 81
Well I did that to check the load lines coming into my main panel. Beyond that though Im a noob. In a box full of 100amp breakers (i think the service to this box is 500 amp, can I use a regular volt meter to test the individual wires coming out of the breaker?
Old 10-09-2013, 07:18 PM   #9
joed's Avatar
If the feed to your shop is underground it could be an underground cable issue.
Old 10-09-2013, 09:00 PM   #10
Yes you can !
But are you sure a noob can poke around in a panel safely ?
Extreme care !
Test between breaker and neutral bar.
Once you have identified the two hots,
Test between the two hots,
Should be 220 - 240v.
Remember take all safety precautions.
Don't do it if you feel uncombfortable.
Old 10-09-2013, 10:51 PM   #11
Rewards Points: 81
Yeah, its time to call an electrician. We flipped breakers tonight until I figured out which one was mine. Its labeled now. But it still didnt fix it. Someone switched my electric stove on and all of a sudden the lights come on. WTH? When we turn on another burner on the stove, the lights get brighter all of a suddent. With one burner on there was 45 volts showing on feed line 2. Not sure what the voltage was when we turn on two burners. Either way, that is weird weird weird to me. That when I turn on the stove, the lights come on but if I turn the stove off, the lights go off. If I unplug the stove or turn that breaker on, nothing will come on. Any ideas?
Old 10-10-2013, 12:50 AM   #12
It must be a 240v stove? You're essentially backfeeding the dead side of the panel through your stove from the other 120v leg. Definitely not something you should be doing. This would be a good time to flip off all 240v circuits.
P.S. you have a stove in your shop?
biglaz is offline   Reply With Quote
Old 10-10-2013, 06:32 AM   #13
PoleCat's Avatar
Rewards Points: 1,646
Any of these panels outside? I have had a couple of 100A double pole breakers just quit working on one side due to exposure.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-10-2013, 05:31 PM   #14
Rewards Points: 81
So the electrician came out and was able to restore power. everything was out all the up to the electrical meter. In front of the meter was a monster 400 amp "knife breaker" which was supplying power to a wall of 8 electrical meters. In between each set of meters was a set of "test blocks". He tested everything out and was able to trace it to one particular cable between one feed on the electrical meter(removed) and a test block. We eventually narrowed it down to the test block. He got out a tool and cranked the nut holding the cables down onto the test block. Tested the feed on the electrical meter and bam, we had power. Went and checked everything else and we were good. Power restored to everything. Still glad I called the electrician to take a look.
Outlet has more than 1 breaker linked to it... Mark C Electrical 13 05-28-2013 08:18 PM
3 way switch trips breaker over night Hazelberg Electrical 5 09-21-2012 09:34 PM
220 volt breaker switch raiden22003 Electrical 13 09-23-2011 12:05 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
