Old 10-11-2010, 05:18 PM   #1
Weatherproofing Outside Light
Today I replaced an old porch light, and noticed that there was no weatherproofing to keep water out -- nothing to keep water from seeping down the outside wall and perhaps into the electrical box. The new porch light was of the same type, and it didn't come with any weatherproofing either. So the outside plate of the new fixture is just flat against the outside brick surface, like the old one was.
Should this be caulked, or is there some other method for weatherproofing an outside light fixture?
MrBill_DIY is offline   Reply With Quote
Old 10-11-2010, 05:55 PM   #2
Master Electrician
Clear silicone.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Thurman (10-11-2010)
Old 10-12-2010, 01:57 PM   #3
Just call me Andrew
I think normal practice is to leave the bottom un-caulked (just do the sides and top), so if water does make it's way in, it can get out.
Andrew
secutanudu is offline   Reply With Quote
Old 10-12-2010, 06:33 PM   #4
Master Electrician
Good point.
Old 10-12-2010, 08:37 PM   #5
" Euro " electrician
frenchelectrican's Avatar
A clear silcone will work but make sure you do not block the bottom of the luminaire or other items so the water can able drain out.
Merci.
Marc
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Grout question poolecw Flooring 11 10-29-2008 08:32 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
