Weatherhead For Photovoltaic System - Electrical - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 12:20 PM   #1
Weatherhead for photovoltaic system
A solar contractor will soon be installing a photovoltaic system on the roof of my attached garage. Instead of running the conduit and wires over the edge of the roof and down the side of the house before entering the the basement, I proposed installing a weatherhead and getting the wires and conduit inside as quickly as possible. My question is, is there such a thing as a weatherhead which accommodates twelve #10 THHN wires? Also, is there a minimum height for such a weatherhead above the surrounding roof? Thanks. Bill
wklopf is offline   Reply With Quote
Old 03-25-2011, 01:27 PM   #2
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
They do make such an animal but you will need to go to an electrical supply store. I doubt if the big box stores would carry it.
HIVOLT is offline   Reply With Quote
Old 03-25-2011, 06:38 PM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,860
What you need is a roof jack and a box, not a weatherhead. A weatherhead is specifically for individual conductors, and THHN cannot be left exposed. Your conductors will be in conduit. So, you run a conduit up through the roof using a roof jack (a flashed penetration for a pipe or conduit, which you would have with a weatherhead anyways), and mount a good sized box on top for the conduit to run into instead of a weatherhead. That way the conductors are not exposed to the weather.
mpoulton is offline   Reply With Quote
Old 03-25-2011, 07:24 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
and how do you propose that he support that box on top of a stick of pipe???
How about flex(liquidtight) and a connector to the solid pipe coming out the roof jack?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
beware humidity system? Emaderton3 HVAC 5 02-11-2010 12:52 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
