We Hate Tamper Proof Receptacles! - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 01:01 PM   #31
Electrical Enthusiast
Rewards Points: 504
I installed some tamper proof receptacles from lowes (forgot the brand) and did not have problems. Maybe one time when I tried to jam a plug into it too quickly, but nothing besides that.
I wonder if it's a brand-specific issue.
Kyle_in_rure is offline   Reply With Quote
Old 12-23-2013, 02:24 PM   #32
Rewards Points: 344
Probably Cooper.
herdfan is offline   Reply With Quote
Old 12-23-2013, 02:52 PM   #33
Rewards Points: 258
The house uses Hubbell TR receptacles.
OP
puttster is offline   Reply With Quote
Old 12-23-2013, 11:50 PM   #34
Licensed electrician
Rewards Points: 1,234
Originally Posted by puttster View Post
Ah, so you are saying the problem is just dirty, dry sticking shutters. I wonder if giving them a good soak in some chemical or oil would help the American style. Though if I want to the trouble of removing them I would probably just replace them with the old style. Any ideas that can be used with the receptacle still in the wall?
Remove the problem one and replace it. No need for anything else. Replacing with non tamper would be against the code article that was already posted.
Old 12-24-2013, 12:32 AM   #35
Rewards Points: 398
Is that a new code? My house was built with all regular outlets throughout (NJ). I recently installed the tamper resistant outlets in the kids bedrooms. Thinking of doing the downstairs lower outlets ones soon too.
Do they make these in the 20a style for my lower kitchen outlets? I've only seen 15a ones.
I found it easier to angle the plug some so the neutral side hits the shutter first then press the whole thing in.
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 12-24-2013, 01:36 AM   #36
Oso954's Avatar
Rewards Points: 738
The code was 2008, but depending on how fast your state adopts code, whether or not they take exception to the article or not, the implementation dates may vary widely.
In Calif, they were not required until 2011.
Oso954 is offline   Reply With Quote
Old 12-24-2013, 02:02 AM   #37
You do not need 20 amp receptacles in the kitchen.
Old 12-24-2013, 06:24 AM   #38
Rewards Points: 3,130
Not gonna get into a discussion of the over-protectiveness of the nanny state. I do wonder, though, just how many young children in the U.S. are killed (or seriously injured) by sticking something into a receptacle. I suspect the actual number is quite small or nonexistent altogether. All five of my children (now grown, with kids of their own) did it at one time or another. A couple did it more often than the rest. Other than being scared witless and occasionally popping a breaker, absolutely nothing ever happened. I have no problem with such devices per se; what I would object to is being forced to use them. Like the AFCIs and bogus radon remediation I was required to install when I built my house, TPRs would be a total waste of my money.
Old 12-24-2013, 10:10 AM   #39
Rewards Points: 115
you will have bigger issues if you try to repair , clean , soak, or modify this recpt. in any way
pokey is offline   Reply With Quote
The Following User Says Thank You to pokey For This Useful Post:
Kyle_in_rure (12-24-2013)
Old 12-24-2013, 10:31 AM   #40
PoleCat's Avatar
Rewards Points: 1,646
My money is on the ones that felt like experiment needed to be repeated.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 12-24-2013, 11:09 AM   #41
Oso954's Avatar
Rewards Points: 738
The numbers used were 2400 children a year (7 per day) receiving emergency room treatment for burns. And though rare, some cases fatal.
You can then ask how many more were treated at home, or did not seek treatment.
When you consider that the vast majority of these are children 6 and under, it is worthwhile.
Old 12-24-2013, 11:18 AM   #42
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
I hate 'assumptions' regarding statistics....
http://www.esfi.org/index.cfm/page/I...tics/pid/12015
Household Injuries and Accidents:
More than 30,000 non-fatal shock accidents occur each year.
Each year in the U.S., more than 100,000 people are treated in hospital emergency rooms due to a scalding injury.
Hot tap water accounts for nearly 1 in 4 of all scald burns among children and is associated with more deaths and hospitalizations than any other hot liquid burns.
Each day, nearly 7 children are treated in hospital emergency rooms for electrical shock or burn injuries caused by tampering with a wall outlet.
In 2007, over 98,000 children ages 14 and under were treated for burn injuries in hospital emergency rooms.
The most common causes of product-related thermal burn injuries among children ages 14 and under are hair curlers, curling irons, room heaters, ovens/ranges, and irons.
In 2009, ranges and ovens were involved in an estimated 17,300 thermal burn injuries seen in U.S. hospital emergency rooms. 36% (5,600) of these burn victims were under the age of 5.
Heating equipment accounted for 58,660 injuries reported to hospital emergency rooms in 2009. Space heaters accounted for 19% of the total injuries, but more than two-thirds of the thermal burn injuries.
For every 10 poison exposures in children, approximately 9 occur in the home.
- See more at: http://www.esfi.org/index.cfm/page/I....akQoJyes.dpuf
The Following User Says Thank You to ddawg16 For This Useful Post:
puttster (12-24-2013)
Old 12-24-2013, 12:10 PM   #43
Originally Posted by Jim Port View Post
You do not need 20 amp tamper proof receptacles in the kitchen.
you sure about that? pretty sure just about every countertop receptacle falls under the requirements.
itsnotrequired is offline   Reply With Quote
Old 12-24-2013, 12:12 PM   #44
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Tamper proof...yes
20A...no
The Following User Says Thank You to k_buz For This Useful Post:
Jim Port (12-24-2013)
Old 12-24-2013, 12:19 PM   #45
Originally Posted by k_buz View Post
Tamper proof...yes
20A...no
ah, i see what he is saying now. i read it as 20 amp receptacles in a kitchen don't need to be tr, because the location or the 20 amp rating makes them exempt.
Tamper proof receptacles? rjniles Electrical 9 10-02-2012 08:27 PM
Color of Receptacles miamicuse Electrical 28 06-16-2012 10:08 PM
Split receptacles in kitchen sanec1 Electrical 30 05-13-2012 03:39 AM
Tamper proof receptacles and 2008 NEC WillK Electrical 21 02-19-2012 10:59 PM
does every plug have to be Tamper proof? kb2187 Building & Construction 2 08-04-2010 03:20 PM
