We Hate Tamper Proof Receptacles! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2013, 07:14 PM   #1
Rewards Points: 270
We hate tamper proof receptacles!
So much cursing at our home, trying to jam the plug into those new outlets. What can we do? Is there a tool I can make or buy such that you can hammer it in, to make the dam slots relax? Can I pop the top or drill a hole or stick a screwdriver in someplace and defeat whatever is in there? I am not up to replacing all the outlets, what else can be done?
putts
puttster is offline   Reply With Quote
Old 12-21-2013, 07:16 PM   #2
Rewards Points: 6,652
I have them in my home, never had a problem with using them. Sounds like you are doing it wrong.
The Following User Says Thank You to gregzoll For This Useful Post:
h.shaabo53 (12-24-2013)
Old 12-21-2013, 07:32 PM   #3
Rewards Points: 746
I've had them for several years, no problems here either.
AandPDan is offline   Reply With Quote
Old 12-21-2013, 07:46 PM   #4
I added them in certain areas where my kids play. At first it was hard for me to plug something in and I thought they were broke, considering that previous times I had no problem. Then one day I plugged right in. I think it all depends on how you line the plug up with the receptacle and give it a little more force then a normal non tamper proof receptacle. The important thing is my kids can't do it.
goodwood232 is offline   Reply With Quote
Old 12-21-2013, 08:10 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,108
They just require some maintenance !
Remove the recepticule, dismantle,
Clean and lube the sliding shutters
Easy stuff !
dmxtothemax is offline   Reply With Quote
Old 12-21-2013, 08:24 PM   #6
Rewards Points: 166
I don't use them much, but I also dislike them. That said, I'll be installing them in my house soon when the kid gets old enough to crawl around and get into trouble.
They are a little annoying to me, but worth the inconvenience for the safety factor.
When I have used them I've found that using a small amount of finesse goes a long way.
dftc is offline   Reply With Quote
Old 12-21-2013, 08:48 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by dmxtothemax View Post
they just require some maintenance !
clean and lube the sliding shutters
easy stuff !
what?!
The Following 6 Users Say Thank You to k_buz For This Useful Post:
jbfan (12-21-2013), Jim Port (12-21-2013), jrclen (12-22-2013), kevinp22 (12-21-2013), oh'mike (12-22-2013), stickboy1375 (12-21-2013)
Old 12-21-2013, 09:53 PM   #8
Licensed electrician
Rewards Points: 1,296
I was scratching my head on that disassemble and lube thing too.
Old 12-21-2013, 10:02 PM   #9
Originally Posted by k_buz View Post
what?!
Has to be a Aussie thing.
Old 12-21-2013, 10:57 PM   #10
Aussie tamper proof outlets use a sliding shutter.
Are the american ones different ?
Old 12-21-2013, 11:30 PM   #11
kevinp22's Avatar
I installed these all over my house when I rewired 2 years ago. just have to get used to them.
turned my back for 10 seconds once and 4 year old was trying to insert screwdriver into a receptacle. thank God for TR.
kevinp22 is offline   Reply With Quote
Old 12-22-2013, 12:28 AM   #12
Rewards Points: 150
Make sure that you are putting the prongs in straight and not trying to put the prongs in crooked because the shutters inside will only open if there is pressure on both the hot and neutral side
romex1220 is offline   Reply With Quote
Old 12-22-2013, 12:47 AM   #13
They learn, just like we did growing up.
plummen (12-24-2013)
Old 12-22-2013, 02:30 AM   #14
Rewards Points: 270
Easy stuff !
That's the kind of fix I was looking for. Though it was less helpful to say "Easy stuff!" instead of actually describing how to dismantle, clean and lube. So pretend I am not an electrician - how do you do it?
Old 12-22-2013, 04:35 AM   #15
Rewards Points: 338
Once you disassemble an American TP receptacle, you won't be able to get back together. It's a liability issue. Go straight in several times to loosen it up a bit. See Q #4
http://www.nfpa.org/safety-informati...al-receptacles
petey_c is offline   Reply With Quote
The Following User Says Thank You to petey_c For This Useful Post:
gregzoll (12-22-2013)
Tamper proof receptacles? rjniles Electrical 9 10-02-2012 08:27 PM
Color of Receptacles miamicuse Electrical 28 06-16-2012 10:08 PM
Split receptacles in kitchen sanec1 Electrical 30 05-13-2012 03:39 AM
Tamper proof receptacles and 2008 NEC WillK Electrical 21 02-19-2012 10:59 PM
does every plug have to be Tamper proof? kb2187 Building & Construction 2 08-04-2010 03:20 PM
