Old 11-12-2012, 06:27 PM   #1
$-way switch wiring
I have a 4-way switch circuit with source power coming in to box1 and going out again.
With power disconnected from box 1, I still measure voltage between ground and red and also between ground and black on the wires between box 1 and 2. About 14 and 20 volts.
Where is this voltage coming from?
Marcel is offline   Reply With Quote
Old 11-12-2012, 06:37 PM   #2
$-way switch wiring
Induced voltage from somewhere downstream of box 2??
mlijoi is offline   Reply With Quote
Old 11-12-2012, 07:02 PM   #3
joed's Avatar
$-way switch wiring
You are using a digital meter and the voltages are phantom voltage induced by capacitive coupling.
Do not PM with questions that can be asked in a forum. I will not respond.
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
