Way To See How Many Amps Something Is Using? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 10:22 PM   #1
Rewards Points: 264
Way to see how many amps something is using?
Is there any way to tell how many amps a line is using, short of connecting a breaker to it and seeing if it flips?
tibberous is offline   Reply With Quote
Old 08-05-2011, 10:32 PM   #2
I=E/R
a7ecorsair's Avatar
I don't have one - yet - but they look pretty neat.
http://www.p3international.com/produ.../P4400-CE.html
Lowes has them for $29.00
This one only works on 120 with a 15 amp limit.
If you are looking to test something that doesn't have a plug you will need a clamp on amp meter.
a7ecorsair is offline   Reply With Quote
Old 08-05-2011, 10:36 PM   #3
seansy59's Avatar
Rewards Points: 258
I have one of them! They are excellent for anything 120v that plugs in. I definatly recommend it if this is what you need.
seansy59 is offline   Reply With Quote
Old 08-06-2011, 12:20 AM   #4
Rewards Points: 264
Thats sweet - little pricey though.
Old 08-06-2011, 12:23 AM   #5
Rewards Points: 506
Use the meter provided by the power company.
jlmran is offline   Reply With Quote
Old 08-06-2011, 03:25 AM   #6
Rewards Points: 1,016
I have one too - very handy. Check around - I think I paid less than $20 for mine.
____________
Vince
Old 08-06-2011, 06:25 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Kill-A-Watt!! FTW
Unless of course you want to monitor a whole circuit. Then you need an amprobe at the panel. This will tell you amps and you have to figure out watts.
Old 08-06-2011, 06:26 AM   #8
Can you explain how to do this?
Old 08-06-2011, 07:37 AM   #9
I=E/R
a7ecorsair's Avatar
Well, if 20 to 29 dollars is too high and a clamp on probe would be even more then you can forget about your project.
The Following User Says Thank You to a7ecorsair For This Useful Post:
Speedy Petey (08-06-2011)
Old 08-06-2011, 08:19 AM   #10
Rewards Points: 506
Are you asking out of ignorance? Or as a means to test my knowledge in such matters?
Old 08-06-2011, 08:23 AM   #11
Yes, I am ignorant. Explain it to me like I am a child.
WTH was with that reply? I was merely asking how it is possible to tell the draw of one circuit or load via the utility meter, which of course meters the service as a whole.
And on that note how is ANYONE supposed to tell the short term draw of even the whole service using the utility meter??? Even an old analog one would be hard to read in small amounts, and quite vague.
Old 08-06-2011, 08:40 AM   #12
Rewards Points: 506
It isnt an ideal method. But if one were to disconnect all other circuits and/or equipment, and only use the device in question, then a current utilization could be determined.
Don't meters have a numerical value (multiplier?) placed on them which is used to calculate wattage in short amounts of time? I recall a thread on this forum which discussed it...but I haven't found it yet.
My reply was sincere...I thought you were testing me.
Old 08-06-2011, 08:43 AM   #13
No, my question was actually sincere as well, hard as it is to believe.
I get what you are saying, but I don't think a utility meter is sensitive enough for small measurements over a relatively short period of time. Your method would definitely work, but I just question the results.
Old 08-06-2011, 09:20 AM   #14
Rewards Points: 152
Had this thread bookmarked from a while back, originally posted by micromind
It's easy to determine the actual watts going through a meter at any given time.
Find the Kh number on the face. For a 200 amp single phase meter it's usually 7.2
Multiply this number by 3600. If it's 7.2, the result will be 25,920.
Divide this number by the number of seconds it takes the disc to make one complete revolution.
For example, 25,920 divide by 3 seconds = 8640 watts. 25,920 divide by 13 seconds = about 2000 watts.
A dryer is typically around 5500 watts, so in this case there's about 3000 watts of other load as well.
The load of a typical house usually runs less than 1000 watts unless an appliance of some sort is on.
I'd start by turning breakers off one at a time while watching the meter disc.
Rob
burnt03 is offline   Reply With Quote
Old 08-06-2011, 09:28 AM   #15
Rewards Points: 506
That's the one...thanks!
Sub-panel selewis Electrical 23 02-21-2010 11:52 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
