Old 03-04-2013, 01:53 PM   #1
Question
Watts Amps Volts using an inverter
Hello!
I have a question today about inverters.
if i have a 12 volt in, 120 volt out 600 watt inverter, what is the input?
is the input 5 amps or 50 amps?
thanks a lot because i want to figure out how many batteries i need to do something.
users8989 is offline   Reply With Quote
Old 03-04-2013, 02:27 PM   #2
Output 600 watts or 5 amps at 120V.
Input 600 watts, or 50 amps plus at 12 V.
Unless you have the specific efficiency factor for your inverter, use 85%. So your actual draw on the batteries will be somewhere around 57.5 amps at full load.
Oso954 is offline   Reply With Quote
Old 03-04-2013, 02:30 PM   #3
thank you
my hopes are crushed now
:P
Tags
amps, battery, inverter, volts, watts
How many volts, amps, watts? does it take to start a fire? Red Squirrel Electrical 15 10-27-2012 09:02 AM
Demand Load Calculations sirsparksalot Electrical 6 05-10-2011 06:42 PM
volts x amps = watts right? Red Squirrel Electrical 11 01-02-2011 12:59 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
