Watts To Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2006, 12:19 PM   #1
Rze
Average Joe
Rewards Points: 79
Watts to Amp
This is sort of a residential question. House has been converted to a theatre. I have been asked to relocate the lighting dimmer packs. Each pack is on a separate 50 amp breaker. I did some quick math and am now becoming worried.
These dimmer packs are 6 channels capable of 2400 watts per channel. If I do the math the entire pack is capable of 14,400 watts. If my calculations are correct, these should each be on an 80amp breaker.
14,400 watts / 240 v = 60 amps. Using the 80% rule, 60amps is 80% of 75, therefore the breakers whould be 80amp (double pole 40amp)
Just need someone to validate my thought processes here.
Thanks!
Rze is offline   Reply With Quote
Old 08-10-2006, 12:51 PM   #2
If the house has been converted to a theater than this is not a residential question. Actually it apears to be a general electrical question.
I agree with your math and this should be an 80 amp circuit. But, a two pole 40 amp breaker is not 80 amps it is 40 amps at 240 volts.
You need a two pole 80 amp and no 4 copper wire.
jwhite is offline   Reply With Quote
Old 08-10-2006, 12:57 PM   #3
Rze
Average Joe
Rewards Points: 79
Perfect, thanks! Thanks also for correcting my terminology. I did mean a two pole 80 amp.
Landscape Lighting? NightScapes Landscaping & Lawn Care 36 06-13-2011 06:37 AM
Watts vs. Volt-Amp Billing? Max P Electrical 19 07-24-2007 07:05 AM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 03:09 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
Amps to Watts Darylh Electrical 14 06-26-2006 11:57 AM
