-   -   Wattage vs. wire size (http://www.diychatroom.com/f18/wattage-vs-wire-size-12447/)
SeanR 10-16-2007 05:55 PM
Is there a formula for this? as based on 120v system.
jbfan 10-16-2007 06:01 PM
P=I*E
Where
P=power in watts
I=amps
E=volts
Code states.
14 awg=15amps max
12 awg=20 amps max
10 awg=30 amps max
SeanR 10-16-2007 06:12 PM
First, thanks for the reply.
So, If I have this right, then the max. wattage for a 120v, with #12 is:
Watts(X)=20*120
X= 2400
is this correct?
jbfan 10-16-2007 06:14 PM
Yep! More letters to make the post long enough!!!
Andy in ATL 10-16-2007 06:19 PM
Ohms law
Just for fun, lets say I wanted to put 28 recessed cans in my big pimp kitchen and I was going to use 65 watt bulbs.
I=p/e or (28x65)/120 or i=15.17Amps
In this case I would have to use 12 AWG CU wire.
Or... lets say I had a 8000watt (or 8kw) heater that operated on 240Volts.
I=p/e or 8000/240 or I=33.3Amps
In this case I would have to use 8 AWG CU wire.:thumbup:
Ohms law is extremely cool even for DIYers to wow your friends at cocktail parties with your knowledge of electrical theory!:whistling2:
p=watts e=volts i=amps r=resistance
If the electrician knows any two of these he/she can solve for the rest. And I was the kid in the eighth grade bi###ing about the fact that i'm never gonna need this algebra crap EVER!:laughing:
SeanR 10-16-2007 06:21 PM
Thank-you there, jbfan.
jbfan 10-16-2007 06:22 PM
And I thought that was me!!!!
Andy, When you taking the test?(Sorta of topic)
Andy in ATL 10-16-2007 06:29 PM
I've got 7 years resi., one year comm. and I'll sit for the GA test in fall of 08 before GA adopts the 08 code. Thanks for asking!:wink: I've become a huge code geek just in the last 18 mos.
jbfan 10-16-2007 06:33 PM
I took mine in 96 in at the Gwinnett civic center.
Good luck.
elkangorito 10-16-2007 10:30 PM
Sorry to ruin the party but what if your 8kW heater is inductive (uses wire coils) & has a Power Factor of 0.8?
P(kW) = E(v) x I x Cos phi (this is for single phase power).
I = P divided by (E x Cos phi)
= 8 000 divided by (240 x 0.8)
= 8 000 divided by 192
= 41.7 Amps.
When calculating power consumption of equipment, the Power Factor must be considered if the equipment is inductive or capacitive.
This formula, P = E x I, is for finding single phase Apparent Power (VA). The formulae for finding True Power (kW) is;
P = E x I x Cos phi (single phase).
P = 1.732 x E x I x Cos phi (3 phase).
Andy in ATL 10-17-2007 01:48 PM
You are totally correct.:thumbsup:
Stubbie 10-17-2007 03:32 PM
Andy's heater had a pf of 1.0.......:tt2:
