Old 03-03-2011, 05:17 PM   #1
wattage
Just had a new light fitting installed and didn't take into account how dull three 20watt halogen bulbs would be..can i replace the bulbs with a higher wattage? if so how high could i go? The light itself isn't on for long periods.
joanna1 is offline   Reply With Quote
Old 03-03-2011, 05:24 PM   #2
wattage
You need to check if the light fitting has a max wattage rating.
Also consider where the light fitting is instaled,
and whats behind it, ( ie - is it well ventilated ).
Check these things before you chamge lamps.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
joanna1 (03-03-2011)
generator wattage jebrover Electrical 5 03-01-2011 03:38 PM
Switch Wattage Rating TipsyMcStagger Electrical 7 08-21-2010 08:06 PM
transformer wattage paulmars Electrical 8 03-20-2009 09:41 PM
Dual Wattage Elements tonyBagadonuts Electrical 4 03-17-2008 06:14 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
