Watt Meter On Power Panel Cover - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 09:27 AM   #1
I have a CH7KK panel. The cover has a small hole cut into the center top area, and a watt meter is installed in that spot. The purpose of the watt meter is to load level the generator. What is the code as far as having something like that in the panel cover? Any ideas? Thanks.
Pirateghost is offline   Reply With Quote
Old 11-01-2011, 09:33 AM   #2
Rewards Points: 6,652
Really need pictures. As for code, it depends on your local, and how they view it. Meters are placed into panels all the time, but not in a load center, usually in their own. Personally, I would remove it, and get a new dead front.
Old 11-01-2011, 09:53 AM   #3
I already called the company (Eaton) looking for a new cover. They said no go, too old. If I can't leave the meter, I may just take the cover down to the local metal shop and have them fix it.
Old 11-01-2011, 10:25 AM   #4
I would not even worry about it. Leave it alone, and just make sure that connections are still tight on all points inside the panel. If you decide to upgrade the panel, due to age, placing the meters to the left or right, along with a whole house surge, would be the only other thing that I would do.
Now, what you could do, if you decide to ditch those meters, is go with something like a Ted, but would need two mtu's, so that you are able to monitor main & standby as needed.
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Temporary power during sub panel install tns1 Electrical 30 11-09-2009 12:42 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
