Waterproof Replacement Plug For Extension Cord - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2012, 06:07 PM   #1
Waterproof replacement plug for extension cord
I've got an expensive, long, heavy-duty extension cord that I use outdoors. The prong for the ground wire broke off and I assume that I need to replace the plug. The original plug was sealed very well, while all of the replacement ones I can find would definitely be leaky. So, I was wondering whether there are waterproof (or, at least somewhat water resistant) replacement plugs available. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 06-24-2012, 06:40 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Daniel Woodhead products are good for watertight plugs and connectors.
Should be available at a local supply house or here's a link for online availabilty http://www.waresdirect.com/products/...e-Rubber252857
wirenut1110 is offline   Reply With Quote
Old 06-24-2012, 06:59 PM   #3
Thanks.
Kinda pricey, but then it would be as good as (or better than) new.
Old 06-24-2012, 09:17 PM   #4
Licensed electrician
Rewards Points: 1,266
Are you using a weatherproof in use cover on the receptacle?
Wiring a plug to a new dishwasher fxk142 Electrical 2 08-06-2008 03:45 PM
extension cord plug ? wel Electrical 3 07-15-2008 07:34 PM
Ele hot water tank and welder sharing circuit wazeaz Electrical 68 03-19-2008 08:17 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Do I have a 30 amp or 70 amp welder. And help wireing it. Tmb9862 Electrical 17 12-04-2006 10:21 PM
