#1 |
Water well pumps
Is there a switch or something that I can get to shut my pump off so that I don't have to go to my breaker box every time? I don't have a holding tank and I'm gonna use it for irrigation only
#2 |
Water well pumps
if it is 208V just break one leg with a heavy duty service switch,if you want to kill both legs and have protection a starter with overloads and stop/start push buttons
| The Following User Says Thank You to biggles For This Useful Post: | g_newport (07-01-2012) |
#3 |
Water well pumps
It's a 220v. Is there a control box I can get to where when I turn the hose on the pump starts and when I turn the hose off the pump shuts off by itself.
#4 |
E2 Electrician
Water well pumps |
| The Following User Says Thank You to stickboy1375 For This Useful Post: | g_newport (07-01-2012) |
#5 |
Water well pumps
Yea I was hoping there was another way.
#6 |
E2 Electrician
Water well pumps |
| The Following User Says Thank You to stickboy1375 For This Useful Post: | mpoulton (07-02-2012) |
#7 |
Semi-Pro Electro-Geek
Water well pumps
It's a cheap, easy, and very well tested solution. It's how every normal well pump installation works. There are other solutions (VFD's and PID controllers, for example), but they are not well suited to this kind of installation.
#8 |
Water well pumps
if the well pump holds anytype of pressure after shut down between the impeller and that shut off valve....a pressuretrol tapped into the pressured line will work.so when you open the valve the pressure drops and the pump runs.might have to break the power feed to the pump into 24Vs with a contactor and transformer to take that amp draw on starts...
#9 |
Water well pumps
Starting and stopping(short cycling), is a cause of early pump motor failure. Try to design your system to minimize starts.
#10 |
Water well pumps |
#11 |
Water well pumps
My well pump wont turn on, I checked with a multimeter at the pressure switch. I have 239 volts on both sides of the switch. The weird part is the contacts remain closed with the power on and off. But no water. what could it be?
#12 |
Water well pumps
240 volts going to the pump and not water could be bad pump. Could be bad wires to the pump. Could be phantom voltage reading with digital meter.
Do not PM with questions that can be asked in a forum. I will not respond. |
| Display Modes | |
| Inline water filter for built-in fridge (water supply line on top) | Druidia | Appliances | 5 | 03-10-2012 01:05 AM |
| Grossly insufficient water supply to toilet wasting water? | mysterylectric | Plumbing | 8 | 01-17-2012 12:19 PM |
| Solar hot water | indatom123 | Green Home Improvement | 0 | 12-19-2010 01:01 AM |
| A blocked water line causing water to loose heat? | Snav | Plumbing | 6 | 05-07-2010 03:18 PM |
| How Do I Properly Shock Chlorinate a Water Softner | classicflytyer | Plumbing | 5 | 07-14-2009 01:15 AM |
