Old 07-21-2011, 09:24 PM   #1
water spilled all over my pump motot
I had an above ground pool installed. As I was about to fill the basket with water to start the pump for the first time, I didn't realize that the valve was open and water spilled out all over the place. I cleaned up the water but it got everywhere. The pump has never been turned on. Did I just ruin my new pool pump?
jw16 is offline   Reply With Quote
Old 07-21-2011, 09:30 PM   #2
Tileguy
Bud Cline's Avatar
Heck no you didn't!
Let it dry out real good I'm sure it will be fine. Is it protected from the rain and pool splashes?
If you have an air compressor blow it out and let it sit for several hours. I'm thinking that should be a totally enclosed motor housing anyway.
Old 07-21-2011, 09:38 PM   #3
Thank you for your reply. I was so worried that I just ruined the motor. I do have the whole pump system set up in a shed next to the pool to keep it out of the elements. There was alot of water but it makes sense that the motor would be somewhat water tight.
Old 07-21-2011, 09:46 PM   #4
Tileguy
Bud Cline's Avatar
You can usually tell if a motor is enclosed. One tell-tale sign is that they might have cooling-fins on the outside of the housing.
Those things used to be called "Totally Enclosed Housings" or something like that. The label might say "TEH" or something similar on it. I can't remember now.
Old 07-21-2011, 09:52 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Most pool pump motors are either totally sealed or "open drip proof". Pretty much any one can be left out in the rain with no ill effects.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 10:03 PM
What is this HVAC Heat Pump System - Water Pipes To Indoor Coil? kentkeith HVAC 20 01-17-2011 05:07 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 09:01 AM
