Water Softener Outlet.... - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 12:42 AM   #1
Rewards Points: 508
Send a message via AIM to theatretch85
Water softener outlet....
I have a new water softener installed as part of my renovation project and there was no outlet existing for a water softener, which means I need to install one. The power supply is a small 12volt DC plug-in transformer with a 12-15ft cord on it, the cord would probably reach to the electrical panel along the wall and I could put the outlet next to the panel. My question is, since this will obviously not take hardly any power, it would be ridiculous to run it on its own circuit.
My question is, what other circuits can this be tied off of? The watersoftener is in the laundry/utility room where the main panel is located and pretty much everything mechanical/plumbing related.
The doorbell transformer is mounted to the bottom of the electrical panel and has been tied off a circuit for the upstairs hallway lights/entry light/exterior lights. Would this be ok to tap into for a transformer that should take less than prob 50 watts? Is there a better option?
theatretch85 is offline   Reply With Quote
Old 04-22-2009, 04:44 AM   #2
Doubtful the softener would use much power except when cycling, generally in the middle of the night. So depending on when you have it programmed for, why tie it to a circuit for upstairs/outdoor lighting. Is there no other circuit (say for a steam iron in the laundry area) where you have another device running by day but not by night. This would cause the least conflict demand wise.
I'm just not a big fan of things all over the house, inside and out on one circuit. IE I flipped a breaker last week to turn off and replace an outdoor receptacle and the lights , clock and computer in the far upstairs bedroom went out...
Chemist1961 is offline   Reply With Quote
Old 04-22-2009, 06:17 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
If it is in the laundry room, why not tie it into the laundry circuit?
jbfan is online now   Reply With Quote
Old 04-22-2009, 12:52 PM   #4
Put it with whereever is easist.
If it was me, I'd put it close to the unit to avoid the cord running across the wall.
If inspected, I'd avoid the controversy of tieing into the washer circuit.
220/221 is offline   Reply With Quote
Old 04-22-2009, 01:03 PM   #5
Rewards Points: 508
I considered the laundry circuit, but neither one of the 2 outlets I am installing for the laundry room would be in a spot where the power pack would reach, so i'd have to install an additional outlet for the water softener anyway. Also, i'd prefer to run it with 14 guage on a 15 amp circuit. Would tieing it into a 15 amp lighting circuit for the basement bedroom/laundry/garage entry way/hallway lights be ok? I already have to do a complete re-wire on this circuit anyway....
As far as power consumtion, I believe the DC power adaptor is probably max of 1 amp at 12 volts.
Old 04-22-2009, 01:09 PM   #6
Put it wherever is easiest.
Wait....I already said that
Old 04-22-2009, 11:29 PM   #7
Rewards Points: 508
Ok, I guess I am wiring it to the lighting circuit downstairs then. Outlet will be a GFCI since it will be in a partially un-finished utility/laundry room and near water. Thanks!
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water Softener "LOWERS PRESSURE" HELP! BobnSofi Plumbing 3 03-23-2009 02:24 PM
Potassium water softener problem Darlok Plumbing 2 02-02-2009 06:08 PM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
