Water Sensing Relay Switch 110V - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 05:53 PM   #1
Water sensing relay switch 110V
I am trying to build a water sensing relay switch. Has anyone tried that before. In general one could buy a cheap water sensor. On closure (water is present) they give away between 1-2Volts. most relais that direct a 110Volt switch have higher control voltages. If you have advice on how or where to get the appropriate relay or a DIY method to make a sensor that closes at a higher voltage.
Thank you,
Gunther
gkern is offline   Reply With Quote
Old 03-21-2010, 06:01 PM   #2
Master Electrician
Rewards Points: 3,680
Thank you,
Gunther
What do you mean they give away 1-2 volts? Are you talking about a water flow switch?
brric is online now   Reply With Quote
Old 03-21-2010, 07:07 PM   #3
Search google.com for the words...
water level switch
http://www.google.com/#hl=en&source=...82fcc58a84fb8f
Billy_Bob is offline   Reply With Quote
Old 03-21-2010, 07:17 PM   #4
some skylites have water sensors that close the lite when rain starts. is that what you're doing
The older I get the better I was
Old 03-30-2010, 08:18 PM   #5
skidrowpete
Rewards Points: 12
relay
you might try your local hvac suppler and get a condesate pump with float switch
skidrowpete is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Taco s501 relay switch wiring threequez Electrical 2 11-06-2009 10:50 PM
Switch from 1/2" to 3/4" main water line? SanDiegoGuy Plumbing 10 04-17-2009 08:12 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 10:50 PM
