Old 09-10-2011, 07:50 PM   #1
water pump breaker humming and tripping
my water pump breaker is tripping---when i reset it, it hums and then trips again------i pulled the disconnect for the pump and reset the breaker and it didn't trip-----just want to make sure if i should be looking at more of an issue with the water pump---thanks
hammer60 is offline   Reply With Quote
Old 09-10-2011, 08:00 PM   #2
Code05's Avatar
Water pump or the wire from disconnect to water pump. Assuming breaker is good.
Code05 is offline   Reply With Quote
Old 09-10-2011, 08:04 PM   #3
Electrician
SD515's Avatar
You pulled the disconnect and the breaker holds when reset, that tells you the problem is in the disco, the wiring from it to the pump, or most likely in the pump itself.
Kyle
Old 09-10-2011, 08:08 PM   #4
Code05's Avatar
Or a bad breaker, no?
Old 09-10-2011, 08:27 PM   #5
Electrician
SD515's Avatar
You beat me to it
Possible. Yes.
Kyle
Old 09-10-2011, 08:34 PM   #6
Electrician
SD515's Avatar
Maybe it's had enough alcohol to drink?
Kyle
Old 09-10-2011, 08:47 PM   #7
i'll check the pump
Old 09-10-2011, 09:05 PM   #8
It could be either the pump, or the breaker !
But it would be cheaper to replace the breaker first !
If a new breaker doent fix it ,
then you have a problem with your pump.
I assume you have checked all the simple things first,
like loose / dirty / faulty connecttions / damaged cord
dmxtothemax is offline   Reply With Quote
Old 09-11-2011, 02:57 AM   #9
" Euro " electrician
frenchelectrican's Avatar
Which type of water pump you have there?
Sub pump or shallow well pump ?
Once you give us little more info we can assit you on this real quick.
Merci,
Marc
Old 09-11-2011, 09:39 AM   #10
Things to check:
Pressure tank waterlogged.
Pump clogged or jammed.
Pipes clogged.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
Code05 (09-11-2011), frenchelectrican (09-11-2011)
