#1 |
DIY'er
Water Near Electrical Panel
There is a water pipe that runs to a outside valve that is not directly above my service panel, but is close.
Is this going to be a problem when I upgrade my service to 200A. With a new larger panel, this pipe may be even closer to the panel. Will it be ok as along as it does not come directly above the panel? It is all copper pipe. Thank You, Jamie |
#2 |
Moderator
Nothing can be in the space immediately above the panel. If the panel were to magically levitate straight upward, it can't hit anything but framing or electrical. The water lines can be very close without violating the code, but can't be directly above it.
#3 |
electrical contractor
Thats why I always use #14 screws to hold my panels in, keeps em from floating up.
Jimmy Life is tough, Life is tougher when you are stupid. |
#4 | |
Master Electrician
Water Near Electrical PanelQuote:
As long as the water pipe will not end up over the panel, you are OK. You could install a drip shield if it will make you feel better.
John from Baltimore One Day at a Time To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. "Experience is what you get when you were expecting something else" "The bitterness of low quality lingers long after the sweetness of low cost is forgotten" |
#5 |
Licensed Electrical Cont.
This is a service replacement. Put the panel back where it was regardless if there is a water pipe above it or not.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#6 | |
Moderator
If it is possible to shift the panel one way or the other to avoid the plumbing, doing so is always advisable. |
#7 | |
DIY'er
There is however a PVC pipe running directly above the panel for the furnaces power vent. This is not a big deal to move if it is necessary. But the power vent pipe should be the only thing that will be in the way of the panels ceiling space. Thank You everyone for the input. Jamie |
| Display Modes | |
| Low hot water pressure | crebive | Plumbing | 38 | 02-26-2013 01:26 AM |
| Leaking pressure relief valve | Chris Magee | Plumbing | 12 | 08-12-2008 08:48 PM |
| Electrical Sub Panel #4 burial wire w/60 breaker | FrankA | Electrical | 4 | 12-31-2007 08:19 PM |
| Splice in Neutral to Panel - OK or Not? | allpraisebob | Electrical | 4 | 08-12-2006 06:54 AM |
