Water Line Next To Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2009, 12:29 PM   #1
Rewards Points: 79
Water line next to outlet?
I am replacing some drywall and want to take the opportunity to move an electrical outlet. It's an easy move but where I'd like to put it has a copper water line running right behind where the box would be -- if I put it there, the pipe will actually rest against the back of the outlet box. This screams "code violation" to me and I figured I'd put it someplace else, but before I did I figured I'd just ask to make sure.
Thanks.
thebigsee is offline   Reply With Quote
Old 10-28-2009, 01:28 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
it is not a screaming violation, but it is not right. Just keep the pipe from actually touching the box and you are fine.
Tags
copper , outlet box , water line
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Outlet installed under sink, under cold water valve? akinito Electrical 3 01-10-2008 08:55 PM
