Water Heater Whip? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 06:55 PM   #1
the Musigician
DangerMouse's Avatar
Water heater whip?
Is this what the inspector wants to see on my water heater? I asked him, and he said it was OK, but I may have described it to him wrong. ( I didn't have it here yet, the wife was at the store getting it.) My main concern is the words WATER HEATER do not appear anywhere on the package. I guess I just want to run it by you guys to be sure it's going to be OK.
Thanks!
DM
Old 09-24-2010, 07:13 PM   #2
Licensed electrician
Rewards Points: 1,630
You will probably need to cut the length down, but the conductors are the correct size and color.
Whether you will be able to connect to the box at the wall would depend on the type of box used there.
Old 09-24-2010, 07:28 PM   #3
the Musigician
Nah, I'll hide any slack inside the wall, the panel is 2' away from the WH! The other orange (approved BEFORE when I installed it!!!) is around 4' because it goes to the far side of the panel.
He did say you could use outdoor wire indoors, but not the other way around, of course.
I just didn't even want to open the package if there was ANY reason this would fail.
The wires are 8" max, I'm hoping the ground will reach the bar! LOL
DM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
