Water Heater Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2008, 11:53 AM   #1
water heater timer
I want to put a timer on my electric water heater.
The heater I have is 240 vac with an upper and lower element rated at 4500 watts and total connect wattage at 4500 on a 30 amp breaker.
I was thinking about this timer: http://www.westsidewholesale.com/ind...@@@&pid=976133
Think itís the right one for me? Over kill, there's a better one? Any suggestions?
coastal is offline   Reply With Quote
Old 10-01-2008, 01:15 PM   #2
joed's Avatar
Rewards Points: 13,716
That unit will work.
What is the purpose of the timer? Do you get lower rates at night?
Old 10-01-2008, 01:21 PM   #3
Thanks.
I only need it in the morning. I've been turning it on when I go to the gym and off when I get home to shower. Other than that, I don't need to have the heater going for the other 22 hrs. The only problem is sometimes I forget to turn it on or off and then there are the days I don't go to the gym.
Old 10-02-2008, 12:32 AM   #4
I have a timer just like that on my water heater and it works great.
I have a "time of use" (TOU) electric meter, so I get lower electric rates in the middle of the night.
BUT a water heater timer can save electricity even if you don't have a time of use meter. The thing to do is set it so you have hot water for a shower in the morning, then just warm water for the rest of the day.
My timer has a manual switch on the outside. If it is real hot and I need a shower in the afternoon, I'll press the button, then wait about 20 minutes and I have hot water.
If I don't use much hot water, the water will stay warm most of the day even though it was heated prior to 6:00am!
Billy_Bob is offline   Reply With Quote
Old 10-02-2008, 01:16 PM   #5
Rewards Points: 240
Just go to HD or Lowes and get an Intermatic (brand name) timer. Inexpensive. Make sure you get the right voltage. They are simple to connect too.
Old 10-02-2008, 03:21 PM   #6
47_47's Avatar
Rewards Points: 76
Billy_Bob, how much are your electrical cost savings and the price of the timer?
47_47 is online now   Reply With Quote
Old 10-02-2008, 06:08 PM   #7
My electric bills in the summer are running about $50 a month and in the winter about $30 a month.
I bought that timer about 4 years ago and don't remember the price.
Now as to my low electric bills, I use every trick in the book to get them this low. This includes added insulation, Energy Star windows, new Energy Star appliances, compact fluorescent bulbs, heating with a woodstove, not using my water heater for hot water except for showers, pre-heating my water with my woodstove, and everything on a power strip and turned off when not in use (like TV, stereo, microwave, all computer stuff, etc.)
Here is a picture of my woodstove hot water pre-heating tanks...
Old 10-02-2008, 07:04 PM   #8
I live in Ontario, Canada and on Oct. 16th our electrical supplier 'HydoOne' is going to install remote control thermostats for the A/C and the H/W.
Somehow, they can send a signal to control these.
The intent is for load shedding during peak usage times.
I've been given to understand that I will be able to control these from the internet, myself.
It would be nice to be able to have a program in my computer that could function like a timer.
Old 10-03-2008, 11:36 PM   #9
Advice worth 2 cents!
Rewards Points: 150
I don't agree with using a timer. The secret to energy conservation is insulation. Install a Watthour meter on the tank and I'd be willing to bet a few bucks that your timer is not saving money, In fact, you could actually be loosing a bit more.
Where do you live? here in canada loosing a few extra calories in the basement is actually a good thing.
-pete
---pete
HandyPete is offline   Reply With Quote
Old 10-04-2008, 09:18 AM   #10
-pete
I'm in Canada also, Pete!
The place that I have was our home, but is now our summer cottage.
I turn off the h/w and a/c when its unoccupied.
What I find that I like, is if I, or anybody else forget, I will be able to shut it off remotely.
Also I will be able to turn up the heat for winter visits.
Old 10-04-2008, 10:41 AM   #11
joed's Avatar
Shutting off the heater and AC when in an unoccupied cottage is a big difference from shutting off you water heater every morning after you use it. I was tihnkg the same thing. How much would he be saving?
Old 10-06-2008, 08:02 PM   #12
I'm in agreement with you joed! After all, once the water is up to temperature, it will shut off anyway.
It won't come on again until the water cools to the lower limit.
So if cooling of the water can be reduced (insulation) it may be the better approach.
Old 10-07-2008, 02:55 PM   #13
Rewards Points: 150
Makes a lot of sense to me! I have a buddy at the office who's a Ham radio operator and his cottage has all kinds of stuff he controls with the radio. Hmmm? NERDS! you might want to try a few radio sites on the WWW.
---pete
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 08:13 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water Heater Timer capt2 Plumbing 4 01-16-2008 06:04 PM
Water Heater Timer piecekeeper Electrical 3 07-19-2007 06:12 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
