Water Heater Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-28-2006, 12:49 PM   #1
Is it a good idea to shut off the water heater if no one is going to be living in the house for a couple of months?
cambece is offline   Reply With Quote
Old 08-28-2006, 01:22 PM   #2
It sure would save on the electric bill. Just dont leave it off in an unheated house in the winter. It could freeze.
Keep in mind that if the breaker is on or off it is still a tank of water. You may want to go there from time to time and run the water to keep the water in the tank fresh. Stagnate water the big problem.
jwhite is offline   Reply With Quote
Old 08-28-2006, 08:49 PM   #3
would it be better just to drain the tank?
redline is offline   Reply With Quote
Old 08-29-2006, 03:48 AM   #4
Heck no. Metal rusts much slower while it is still covered in water. Less oxigen in contact with its surface.
Unless freezing is the problem, and you cant get the electrics back on. Then it is your only choice.
Old 08-29-2006, 08:03 AM   #5
Long-Time DIYer
Mike Swearingen's Avatar
It is always best to turn off the water and the water heater whenever leaving a home unattended for even a weekend.
Burst water hoses can badly flood a home (I know this one from long-ago experience), as well as other major leaks that can occur.
Electric water heaters consume about 14% of your electric bill if you're "all electric", so that's an energy saver.
Also, of course, you never drain a water heater without turning off the power first. If you leave it setting up for an extended period, I would completely flush the tank and hot water lines before using it again.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-31-2006, 09:08 PM   #6
You could not imagine
I do work for a restoration company, last week I received a call to replace a panel. The owners of the house went on vacation and a pipe broke in the basement, it leaked for 2 weeks. The whole basement was filled with water. The baseboards and the drywall on the first floor had mold growing on them. I went there a day after they found it, and you would not believe the smell and the mess.
BIGRED is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 06:08 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
