Water Heater Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2013, 09:58 PM   #1
water heater problem
I wanted to take a quick peek inside the (metal) box that has the on/off switch for my water heater. As I opened it up, I saw a spark. I'll definitely never do that again without turning off the power first. Anyways, I didn't get zapped and no breaker was tripped, but the water heater quit heating water. The switch looked like it might have taken some damage, so I replaced that, which didn't help.
I took off the panels on the water heater to check that power is getting to the heating elements. I get no voltage when I measure across the top 2 leads, but each individually gives 115v when measured to ground. So, power is getting there, but it doesn't seem right that I don't get 220v across any combination of the leads. I just wanted to check with the experts to see if this is the way it's supposed to be.
The water heater is on a 30 amp circuit with 10 gauge (red and and blue) wires. There are other similar circuits (220v dryer outlet, 220v range, etc.) that seem to be wired the same way. The water heater breaker looks like it needs replacing, since it doesn't snap with much authority. But, I don't see how that could be preventing water from heating.
I'd really like to get hot water back by tomorrow (the wife, even more so...), so any help would be greatly appreciated. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 01-05-2013, 10:09 PM   #2
dSilanskas's Avatar
Take your panel cover off and test for voltage across the two screws on the breaker you should have your 220 if you don't test each screw to ground and if you have only 120 volts you need to replace the breaker
dSilanskas is offline   Reply With Quote
Old 01-05-2013, 10:11 PM   #3
Licensed electrician
Rewards Points: 1,258
Can you check for voltage at the breaker terminals? Did you try to reset the breaker?
Old 01-05-2013, 10:56 PM   #4
Rewards Points: 1,192
Turn in your tools.
bobelectric is offline   Reply With Quote
Old 01-05-2013, 11:16 PM   #5
Missouri Bound's Avatar
Originally Posted by bobelectric View Post
Turn in your tools.
Do you want it your way or the right way?
Old 01-06-2013, 12:15 AM   #6
dmxtothemax's Avatar
Rewards Points: 5,102
You have probably lost one hot !
And your measuring backfeed.
Were the wires connectted to the heater when you measured ?
Try disconnectting the wires from the heater,
then measure again,
if its a backfeed situation this will show it up.
dmxtothemax is offline   Reply With Quote
The Following 2 Users Say Thank You to dmxtothemax For This Useful Post:
NJMarine (01-06-2013), zappa (01-06-2013)
Old 01-06-2013, 11:55 AM   #7
Problem solved---it was indeed a bad breaker. Thanks for all of the (non-sarcastic) comments/suggestions.
Old 01-06-2013, 06:08 PM   #8
Was this causing you to lose one of the hots ?
Water heater issues?!? NJdan Plumbing 1 06-04-2015 08:42 PM
Question on return line for water heater daluu Plumbing 10 09-09-2012 11:38 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 12:35 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
