Water Heater + Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2013, 07:22 PM   #1
Rewards Points: 34
Water heater + main panel
We are finishing up plans for a new house and are considering building in a dedicated closet for a variety of elec./service/mechanical items. Specifically, the main electrical panel, CATV/ethernet hubs & modems, security system master panel and an electric water heater.
Other than the usual side and front clearances for the main electrical panel, are there any NEC codes concerning co-locating the water heater and main panel in the same closet?
Dusky is offline   Reply With Quote
Old 03-09-2013, 07:31 PM   #2
Rewards Points: 83
6 foot
mech_gui is offline   Reply With Quote
Old 03-09-2013, 07:55 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Originally Posted by mech_gui View Post
6 foot
Care to tell us where you found this mystery code?
The Following User Says Thank You to Speedy Petey For This Useful Post:
jbfan (03-09-2013)
Old 03-09-2013, 07:55 PM   #4
NO. Other than standard panel clearances there is no restriction regarding proximity to the water heater.
Old 03-09-2013, 08:00 PM   #5
Rewards Points: 34
Thanks. Much appreciated.
Old 03-09-2013, 08:00 PM   #6
Rewards Points: 83
Seemed like good number, reasonable
or
Memory 110.26 NEC some where.
Old 03-09-2013, 08:00 PM   #7
Rewards Points: 14,312
Gas, electric?
With gas there's some ventalition issues.
Speedy Petey (03-09-2013)
Old 03-09-2013, 08:21 PM   #8
TTW
TTW's Avatar
or
Not there, just read it.
Elec water heater should be fine.
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 03-09-2013, 08:36 PM   #9
Rewards Points: 83
Oops that was for large amperage equipment
Old 03-09-2013, 08:57 PM   #10
or
"Seemed like good number"? Seriously???
So you just throw out supposed code facts regardless of whether they are right or not.
Old 03-09-2013, 09:05 PM   #11
Rewards Points: 83
It seemed like a good number when I read the post? the OP didn't say how big the room was, what the constraints were...error on the large side I say. Isn't 6' the work space requirements around electrical equipment 1200A or larger?
Shouldn't the architect know what the requirements?
I said from memory..I said oops.
Old 03-09-2013, 09:10 PM   #12
The room size is irrelevant, as long as working clearances are met.
Once again, irrelevant.
Old 03-09-2013, 09:14 PM   #13
Rewards Points: 83
I concede I was being
Re-plumbing entire house & water heater questions/advice Gerb10 Plumbing 35 03-12-2013 01:16 PM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
