#1 |
Water Heater Electrical Requirements
I got a free water heater from my electric company and am trying to install it. My weak point(more like no clue) is the electrical part of the installation. I was installing it in a utility room that has 2 220V plugs.
Is there a way to use that plug or the wiring from that plug to hardwire the water heater? I just spent a fortune upgrading the wiring and I didn't think about this when they were out because I was going to get gas. |
#2 |
"So I Re-Wired It"
I would say hard wire it. Are the recepticles 30amp?
Knowledge is Power, but 240v can Keel You!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Yeah, it is. I'm trying to cheat the system somewhat. My electric company offers a free water heater and my gas company offers $800 to switch to a tankless. I'm trying to get this up so my electrical company is happy and then converting to a tankless.
I may end up keeping the electrical heater if it is sufficient though. My box is full and the electrical company wanted $1000 to add a subpanel. |
#4 |
"So I Re-Wired It"
Well if the recepticle is near the water heater, you could remove it and put in a junction box.
Then run 10/3 from j box to water heater. If the panel is nearby, it would be best to run new 10/3 from the existing 30amp 2 pole breaker.
#5 | |
Water Heater Electrical RequirementsQuote:
Is there a safe way to add more of the same wire so that I have enough from the j box to the water heater? It's new wiring so I'd be able to get the exact same wire but as far as connecting them. On my jeep I'd use electrical tape but obviously you would not use that in this situation. |
#6 |
"So I Re-Wired It"
Yes, it should be #10/3. That is two hots, one grounding conductor, and bare ground. 4 wires, black red white bare.
Get the length you need to run from the j box to the water heater. Obiously not straight, the wire must be secured from A to B. Yah, black tape is not sufficient. Use proper sized wire nuts instead. Also if the j box is metal you must attach a piece fo bare copper to a ground screw(sold separately) on the metal box. Then twist together this "pigtail" with the other two bare copper wires, and nut them. When nutting wires, use linesman or needlenose pliers to twist them together first. Simply putting a wire nut on is not sufficient to hold wires together.
#7 |
Electrical Contractor
A water heater should only need a 10/2.
| The Following User Says Thank You to wirenut1110 For This Useful Post: | brric (08-13-2012) |
#8 |
Licensed Electrician
and a disconnect if not within sight of the panel
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
| The Following User Says Thank You to k_buz For This Useful Post: | Kapriel (08-14-2012) |
#9 |
A "Handy Husband"
You will get more than a few different opinions on that comment. BTW I twist but many do not.
Location: Coastal South Carolina Last edited by rjniles; 08-13-2012 at 05:46 PM. |
#10 | |
Thread killer
You can have it good, fast or cheap. Pick two. |
| The Following User Says Thank You to Canucker For This Useful Post: | stickboy1375 (08-13-2012) |
#11 | |
E2 Electrician
Most wire nuts do not require pre-twisting, and to prove it to yourself, twist one on without pre twisting and then remove the wire nut, you will be impressed how nice it came out. ![]() BTW, I twist sometimes, usually out of habit from being in the trade (x) amount of years.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#12 | |
"So I Re-Wired It"
Glad u guys chimed in anyway
| The Following User Says Thank You to MisterZ For This Useful Post: | stickboy1375 (08-13-2012) |
#13 | |
E2 Electrician
| The Following User Says Thank You to stickboy1375 For This Useful Post: | MisterZ (08-13-2012) |
| Display Modes | |
| Tankless Water Heater | a7ecorsair | Plumbing | 56 | 05-04-2012 10:17 AM |
| rumbling pipes and leaking pressure relief valve | rogerwright | Plumbing | 21 | 04-14-2012 03:35 PM |
| no water at sink after water heater removal | rebelbull | Plumbing | 2 | 07-19-2011 01:37 AM |
| Water heater drain mechanism (10 year old) | guptaalok | Plumbing | 1 | 01-02-2009 06:40 AM |
