#1 |
Water Heater Disconnect
I am in the process of buying a Dual Element 4500 watt Electric Water Heater that pulls 18.75 Amps.
My question is: Does it matter whether I get a 30 Amp or 60 Amp Disconnect? Would I be safer with a 30 Amp Disc., in case there is a short and it starts pulling more than 30 amps? |
#2 |
Master Electrician
Does not matter. Circuit should be rated at only 30 amps anyway.
#3 |
Licensed Electrical Cont.
Water Heater Disconnect |
#4 | |
Electrical Contractor
Water Heater DisconnectQuote:
It offers no protection from overload in anyway.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#5 |
You talking to me?
not sure it is clear to you so, a bit of explanation.
The rating of the disconnect is the maximum sized circuit you can use it on. With the 30 amp, you can run up to a 30 amp circuit through it. With the 60 amp disco, you can run up to a 60 amp circuit through it. You shouldn't need over a 30 amp disco since you would be running a 30 amp circuit. You can use a 60 amp disco if you want though. |
#6 |
The water heater specifications probably give a maximum circuit rating as well as a recommended (30 amp) circuit rating.
The gauge of the cable conductors (any cable on that branch circuit) imply a maximum circuit rating. If you install a disconnect switch with a higher rating for futureproofing purposes, you would not be able to upgrade the circuit to a higher ampere rating unless all other components in the circuit are compatible with that rating.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 12-27-2010 at 10:18 AM. |
| Display Modes | |
| How to properly drain and flush a hot water heater? | speedster1 | Plumbing | 9 | 04-17-2012 10:55 PM |
| Oil fired furnace and hot water heater question | steveinpa | Plumbing | 3 | 08-10-2010 09:42 AM |
| water heater drip | kdange1 | Plumbing | 5 | 05-04-2010 04:24 PM |
| Water heater pressure relief valve confusion | Flt_Simulation | Plumbing | 4 | 07-11-2009 11:02 AM |
| Water connections for new water heater | diggerdave | Plumbing | 16 | 03-16-2009 11:36 AM |
