Water Heater Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 10:56 AM   #1
Rewards Points: 77
I'm replacing my 20 year old 45 gal water heater with a new 80 gal unit. Both are 4500 watts. Currently I have a 20 amp breaker, which works fine. The manual for the new unit calls for a 25 amp breaker. Is there any reason to replace my 20 with a 25, if the 20 isn't tripping? Wire is 10/2 nm-b.
daveplot is offline   Reply With Quote
Old 08-24-2013, 11:02 AM   #2
Rewards Points: 14,282
Need to change the breaker.
Old 08-24-2013, 11:06 AM   #3
Rewards Points: 77
Can I go to 30 amp since that is all that is available locally (even at electrical supply shop). Or must I get 25 amp?
Old 08-24-2013, 11:12 AM   #4
Rewards Points: 236
That water heater should be on a 30 amp circuit. Two pole 240 volts.
There is no such thing as a 25 amp breaker. So you go up to the next size. 30.
You have the right size wire by the way.
Old 08-24-2013, 11:22 AM   #5
Rewards Points: 77
A GE THQL2125 would be the 25 amp breaker for my application, which I can get Tuesday, but I can do the swap this weekend with a THQL2130 from a local store.
Old 08-24-2013, 01:56 PM   #6
Rewards Points: 508
Send a message via AIM to theatretch85
Haha, I thought the same thing when the inspector said I needed a 25 amp breaker for my A/C! I was surprised when I found they do exist, though only online it seems!
Knowing that the 25 amp breaker exists, i'd install the 25 amp breaker...
theatretch85 is offline   Reply With Quote
Old 08-24-2013, 02:46 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Since a 30 amp breaker is fine for #10 cable, I would use the locally available (and cheaper) 30 amp as opposed to a special order 25 amp.
And would not think twice about it.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Jim Port (08-24-2013)
Old 08-24-2013, 03:06 PM   #8
Rewards Points: 77
It sounds to me that the NEC would permit either 25 or 30 wouldn't it?
422.13 states 125% which would be 25 amps
422.11(E)(3) states 150%, which would be 30 amps
The panel/circuit is from the 70s... So I'm assuming old code stated the current 20 amp breaker is ok.
Old 08-24-2013, 03:14 PM   #9
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
A 25 or 30 amp breaker will be fine.
All manufacturers make 25 amp breakers now.
wirenut1110 is offline   Reply With Quote
The Following User Says Thank You to wirenut1110 For This Useful Post:
brric (08-24-2013)
Old 08-24-2013, 03:18 PM   #10
A "Handy Husband"
rjniles's Avatar
The 20 amp breaker never would have been code compliant
4500 / 240 = 18.75 amps x 125% = 23.5 amps.
Minimum breaker 25 amps (most common 30 amps)
Old 08-24-2013, 04:05 PM   #11
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
They have for as long as I have known. A real supply house will have them in stock in the brand of their choice.
But I agree. A 30A is FINE and typical for a 4500 watt water heater. I cannot think of any reason why a mfg would call for a 25A if #10 is used.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (08-24-2013), Kyle_in_rure (08-26-2013)
Old 08-24-2013, 04:34 PM   #12
Rewards Points: 582
go to the local lowes..or hd get a 30 amp breaker for your new water heater project complete...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
COLDIRON (08-26-2013)
Old 08-24-2013, 07:37 PM   #13
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Yes you can actually get 25 amp 2 pole breakers,I argued with a guy one time for an hour saying you couldnt get one either.
Next time I was at the homeless depot after that little discussion I actually saw one on the shelf!
Boy did I feel like a dumbass,of course I always used 30s anyway since I kept them on my van.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
ben's plumbing (08-24-2013)
Old 08-25-2013, 07:16 AM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
25A is a standard breaker size according to the NEC...I should hope they make 2P 25A breakers.
The Following User Says Thank You to k_buz For This Useful Post:
ben's plumbing (08-25-2013)
Old 08-25-2013, 06:52 PM   #15
kbsparky's Avatar
I use `em all the time:
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
stickboy1375 (08-26-2013)
Tankless hot water heater during winter when water shut off jdabs Plumbing 3 07-10-2012 12:50 AM
Tankless Water Heater a7ecorsair Plumbing 56 05-04-2012 09:17 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
