Water Heater On 100 Amp Pannel? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2008, 08:24 PM   #1
Question
water heater on 100 amp pannel?
i have (2) 100 amp service pannels. My current hot water is fed from the boiler on my furnance. i want to install an electric water heater but dont understand i f i can put a 240volt water heater into a 100 amp servive pannel?
Brett9821 is offline   Reply With Quote
Old 06-02-2008, 08:39 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Certainly you can. Provided the service load is not at or near capacity.
Old 06-02-2008, 09:11 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Brett,
I'm no pro Like Speedy, just an old DIYer.
If your panel can handle it, you need to install a 30 amp 240v breaker with 10/2-with-ground wiring to the water heater.
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-03-2008, 12:04 PM   #4
Rewards Points: 266
What's wrong with the old water heater?
junkcollector is offline   Reply With Quote
Old 06-03-2008, 05:08 PM   #5
never had one
Hot Water Heater Switch or Meter?? tvanthoff Electrical 6 12-28-2007 09:14 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
