Water Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 07:42 AM   #1
Question
Water ground
I have put a new electrical service panel and meter in to my shop and going to run some water over to the shop from my well.
What do I need to do for a water ground if I am using PVC, how do you bond it??
fishfry is offline   Reply With Quote
Old 06-15-2011, 07:57 AM   #2
Licensed electrician
Rewards Points: 1,628
PVC is non-conductive. It would not need to be bonded.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Basement bath plumbing rough in allowing ground water to enter VooDu Plumbing 1 01-07-2010 01:09 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 05:37 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
