Water And Electricity.... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 07:33 AM   #1
the Musigician
DangerMouse's Avatar
Water and electricity....
I need to have the water heater in the same area as my breaker panel, are there restrictions or code as to "how far away from", or "waterproof separating walls", etc. I need to know before I start?
Also, they'll be in a bedroom, so that likely makes it different as well?
Thanks!
DM
Old 06-05-2010, 07:55 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Nope. It is pretty common for the water heater to be right next to the panel.
Besides, what is the likelihood that the water heater will spring a leak and spray the panel. At the same time, what is the likelihood that ANY water pipe in the vicinity of the panel, or any other electrical, spring a leak and soak everything?
Plumbing and electric occupy the same spaces ALL over your house. This is a NON-worry.
Old 06-05-2010, 08:05 AM   #3
the Musigician
and occupying a bedroom space is OK too?
DM
Old 06-05-2010, 09:04 AM   #4
As long as proper clearances and restrictions are met, absolutely.
Old 06-05-2010, 09:53 AM   #5
the Musigician
I have panel clearance covered, thanks to ScubaDave's Picture post in another thread, any WH concerns?
DM
Old 06-05-2010, 10:27 AM   #6
That I am not sure of. That is a plumber issue.
Sorry.
Electricity in water supply BimmerRacer Electrical 5 02-02-2010 08:39 AM
Is there a way to tell what's using the electricity from panel? Piedmont Electrical 9 02-12-2009 12:04 AM
Hot Water Recirculation Issue jeverly Plumbing 7 02-08-2009 07:44 AM
Tankless or tank, but not both gp_wa Electrical 43 10-15-2008 10:08 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
