Water Bond - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 12:54 PM   #1
water bond
where can i get a water bond kit for an above ground pool or can i make one myself
rhope727 is offline   Reply With Quote
Old 05-24-2012, 01:03 PM   #2
kevinp22's Avatar
you mean to bond your electrical panel to the water pipe coming into your house?
if so, I dont think there is a kit but here are a few pointers
1. you must be comfortable working inside your panel to do this (shut off the main when working on the panel)
2. Generally use #4 copper wire (bare or insultated, I used green insulated) unbroken from the main panel neutral bus to the water pipe within 5 feet of its entrance to the house. Install jumpers over water meter (you can connect your wire above and below the meter or install a separate length of #4 copper for the jumper wire) and between cold and hot water at the water heater.
3. use UL listed clamps to connect to the pipe
4. if all your piping is PVC you dont do any of this
if not, i dont know what you are referring to....
kevinp22 is offline   Reply With Quote
Old 05-24-2012, 01:09 PM   #3
water bond
i forgot to say the bond is foe an above ground pool
Old 05-24-2012, 01:16 PM   #4
kevinp22's Avatar
then I have no idea but someone will be able to help you.
also, try searching past threads as I think this issue has come up before
good luck
Old 05-24-2012, 05:39 PM   #5
Master Electrician
Rewards Points: 3,768
http://www.goodfriendelectric.com/ge...urndy_pool.pdf
Google "pool water bonding" for more choices.
brric is online now   Reply With Quote
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 01:05 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
