Washing Machine Timer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2009, 04:28 PM   #1
Washing machine timer
What is the proper way to replace the timer on my Whirlpool washing machine, model #lsq9564jq0, I don't want to make the situation worse.
nonuttin is offline   Reply With Quote
Old 02-05-2009, 05:03 PM   #2
Try the appliance section or approach it like you did when you were a kid and took your bike apart.
All I can offer is, unplug it first.
220/221 is offline   Reply With Quote
Old 02-05-2009, 06:05 PM   #3
Rewards Points: 874
First, you need to look up the model number to get the part number. Once you get the new timer, you will find that all connections are quick-connect and you can easily replace it if you take one wire at a time.
There are lots of wires to be disconnected and reconnected, so the best option is to have both timers side by side, and pull one wire off the old, and onto the new at a time. That way, you know that you are getting it right.
There may also be several large plastic connectors on the timer, instead of simple quick-connect lugs. I haven't replaced one in a long time, and they all used the quick-connects before computers took over. If yours is CPU based, then it will most likely be plastic multiple pin connectors, and your timer will be much more expensive than the old mechanical ones. I used to buy the timers for around $50.
And of course; make sure the machine is unplugged before you start!
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-05-2009, 06:23 PM   #4
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
By the looks on the drawing, it looks like it's just a harness that's plugged in.
http://www.appliance-parts-warehouse...arts-94439.cfm
wirenut1110 is offline   Reply With Quote
Old 02-05-2009, 08:07 PM   #5
Don't get cut on sheet metal edges. Don't chip the enamel.
Old 02-05-2009, 08:30 PM   #6
Rewards Points: 874
Good advice! There's so much sharp metal in those appliances. I got cut while replacing the belt in a dryer.
FW
Old 02-05-2009, 08:45 PM   #7
FW
Just call me lefty!
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 06:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
