Washing Machine Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 01:18 PM   #1
What kind of outlet and what kind of wire do I need to wire an outlet for a washer?
Also, how close can the outlet be to the water pipe supplying water to the washer?
Vikeologist is offline   Reply With Quote
Old 11-30-2009, 05:56 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
A basic washer take a 15 amp recepticle.
A laundry circuit is required to be on a 20 amp circuit, a duplex 15 amp recepticle on a 20 amp circuit will work.
If your area is on the 08 nec, then if you are 6 foot or closer to a laundry sink, the recepticle will need to be gfci protected.
As close to the pipes as you want to put it.
Outlet location for washing machine markinmich Electrical 32 06-10-2013 12:37 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 08:16 AM
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
