Washing Machine Motor Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 05:12 PM   #1
I have a Maytag 1/2 H.P. 120 Volt 60 HZ 8 Amp motor. It has 6 wires, red yellow, white, purple, orange, and black. It is model S68PXMBP-1043. I am going to use it in a project not in a washing machine. Does anybody know how to wire this or what the different wires are for?
coopermor is offline   Reply With Quote
Old 03-23-2013, 05:16 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
An ohm meter will tell you which ones are the motor windings....chances are it's a multi-speed motor
You just need to find the manual on the washer to be sure.
Old 03-23-2013, 05:18 PM   #3
So I just need to apply 110 volts of current to the 2 motor windings?
Old 03-23-2013, 05:19 PM   #4
eastcoastsparky's Avatar
Rewards Points: 150
You just posted this exact question on electriciantalk.com
eastcoastsparky is offline   Reply With Quote
Old 03-23-2013, 05:29 PM   #5
Rewards Points: 1,192
And they sed..."Dis Site is for professionals only,Jack.
bobelectric is offline   Reply With Quote
Old 03-23-2013, 05:38 PM   #6
Rewards Points: 150
It moved to this site so quick he didnt even get busted by the mods
Old 03-23-2013, 10:21 PM   #7
Idiot Emeritus
Rewards Points: 1,492
I'm guessing here more than anything else, but I'd say that red and black are start windings, the other 4 are run windings of two different speeds.
This can be verified with a simple ohm meter.
If there's a capacitor, red and black will likely show resistance, but only for a second or so. This is because the capacitor has charged up to the output voltage of the meter. If you can short the capacitor, you'll read a constant resistance across red and black.
Measure resistance on the other 4. There should be two pairs; two wires that have resistance across them but no others. And the other two wires should also have resistance.
If the above is true, splice red to one wire of a pair, black to the other. Apply 120 volts to this connection. Insulate the two unused wires.
This will result in a speed (usually 1725 or 1140 RPM) and a direction of rotation. If the rotation is wrong, swap the red and black and it'll turn the other way.
To get the other speed, splice red to one wire of the other pair, black to the other wire of that pair.
If you can post the resistance readings of each pair of wires before you start, it'd be helpful.
Once again, this is a guess based on my knowledge of motors in general.
Rob
micromind is offline   Reply With Quote
Old 03-24-2013, 11:35 AM   #8
I measured the resistance of the wires and this is what I got.
Red & Black 4.0
Purple & Yellow 3.8
White & Orange .7
Yellow & Orange 2.2
Old 03-24-2013, 03:22 PM   #9
Idiot Emeritus
Red & Black 4.0
Purple & Yellow 3.8
White & Orange .7
Yellow & Orange 2.2
This looks more like a consequential pole rather than a two-winding motor. If so, low speed will be 1/2 of high speed.
Connect the incoming hot to white. This is most likely one side of the thermal overload.
Connect black to orange. Orange is the other side of the thermal and black is one side of the start winding.
For high speed (most likely 1725 RPM), connect red and the incoming neutral to yellow. Insulate purple.
For low speed, connect red to yellow and the incoming neutral to purple. If it doesn't start well (or maybe not at all....), connect red and neutral to purple and insulate yellow.
If it turns the wrong way, swap black and red.
Rob
Old 03-24-2013, 03:26 PM   #10
Ok thanks. What about grounding the motor? Do I need a ground wire, does it just attach to the motor frame or any specific wire?
Old 03-24-2013, 03:33 PM   #11
Idiot Emeritus
Anywhere on the frame is good if there's not a specific place to connect the ground.
Old 03-24-2013, 04:07 PM   #12
I spliced red to one the neutral and black to the hot wire. I started spinning it by hand, I then turned on the motor and it turned at a very low speed while smoking.
Old 03-24-2013, 05:07 PM   #13
Idiot Emeritus
That's because only the start winding was energized. In order to operate properly, both the start and a run winding must be energized at the same time.
Connect the incoming hot to white. Yes, white is hot, not neutral. This is normal for a motor.
Connect orange to black, nothing else.
Connect the incoming neutral to both red and yellow. 3 wires in this splice.
Insulate the purple. It will be energized, so don't let it touch anything.
Old 03-25-2013, 06:59 PM   #14
I wired it as you said but when I turned it on it started smoking and popping. Do you know why this might be happening?
Old 03-25-2013, 10:55 PM   #15
Idiot Emeritus
It's possible that when the red and black were connected and started smoking that the motor was damaged enough to cause it to fail in this way.
Smoke coming from a motor is caused by the insulation in the windings overheating. It's almost always bad, and often results in shorted windings.
Tags
motor , washing machine , wiring colours , wiring diagrams
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 12:07 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 08:46 AM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
