Washing Machine Circuit To Piggy Back One 60w Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2014, 07:00 PM   #1
Rewards Points: 1,584
washing machine circuit to piggy back one 60w light?
I have a duplex property each unit has its own utility room.
In each utility room are the individual unit's own washer, dryer, hot water heater etc.
Each unit has it's own electrical panel.
Everything in utility room A are powered by circuits from panel A, while everything in utility room B are powered by circuits from panel B EXCEPT the overhead pullchain light bulb in B.
I didn't realize this until I had to trouble shoot something and found this by accident. This means tenant A has been paying the utility room lighting for tenant B all along...its probably insignificant, someone turns it on the few minutes each time to wash, dry or collect a load perhaps twice a week.
Still I would like to get it addressed. The distance to the panel is over 100 feet and very limited access to the attic.
Is it OK to take the currently dedicated circuit for the washer and splice off to power the pull chain light bulb?
miamicuse is offline   Reply With Quote
Old 07-18-2014, 07:58 PM   #2
Rewards Points: 12,882
Time to get rid of that old pull cord and install a comb switch and outlet.
Old 07-18-2014, 08:03 PM   #3
Rewards Points: 1,832
It is certainly doable and in this case its a good idea. I see no harm. However there is one irony. Code wise it may not be allowed since the NEC requires a dedicated 20amp circuit for the washer, and this circuit can not feed anything else, other than outlets within the same laundry area. If you were to run a #12 from the outlet to the pull chain light nothing remotely dangerous would happen (its no different then with any other circuit), but again, its one of those silly code rules that frowns upon it.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
MTN REMODEL LLC (07-20-2014)
Old 07-20-2014, 07:44 PM   #4
Rewards Points: 808
Is there another nearby light or receptacle that can be tapped into?
IslandGuy is offline   Reply With Quote
The Following User Says Thank You to IslandGuy For This Useful Post:
Old 07-20-2014, 08:39 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,450
Jump and Island........
MTN REMODEL LLC is offline   Reply With Quote
Old 07-20-2014, 09:27 PM   #6
That was the question which lead to the idea of tapping into the washing machine circuit.
Unfortunately there is no nearby circuit I can tap into.
Utility Room A
PANEL A - 240V circuit for dryer
PANEL A - 240V circuit for hot water heater
PANEL A - 120V circuit for washer PLUS overhead light for utility room A PLUS overhead light for utility room B.
Utility Room B
PANEL B - 240V circuit for dryer
PANEL B - 240V circuit for hot water heater
PANEL B - 120V circuit for washer
They already tapped into the washer circuit for BOTH overhead lights. Now I need to break it up so one tenant does not end up paying the electric bill for the other. There is nothing nearby that I can tap into. There is another 240V sprinkler pump circuit, a 240V well pump circuit.
Old 07-20-2014, 10:28 PM   #7
Rewards Points: 808
Well, like Jump-Start said, removing the B fixture from the A washer circuit corrects that problem, putting it on the B washer circuit isn't any worse than it was before, plus nobody is paying for someone else's power. But technically, it's a code violation.
Old 07-20-2014, 10:41 PM   #8
Rather then going all technical and anal retentative about it, give the one party a $5 reduction in rent which is a X multiple of what a 60W light costs to run 24/7.
Not kidding....
Old 07-20-2014, 11:14 PM   #9
Not kidding....
That would be an easy solution but it's a no go.
The landlord tenant agreement makes this complicated and I could be liable in the future for being responsible for the TOTAL of ALL electric bills of tenant A if he/she decides to make this difficult. I can't simply shake hands with tenant A and reduce rent by $5 or whatever without an addendum to address it.
Furthermore, it's a problem that will still be there after the current tenant moves out and a new one moves in. So I see whatever temp arrangement as just "temp".
My RE attorney said my options are (1) separate the wiring so no one is paying for someone else's electric, or (2) me the landlord pay for all electric for both tenants and raise the rent to offset. There is really no in-between solution that may not bite me in the future.
Now there is one possible alternative which is to use battery powered LED lights for both and I go change battery every few months or whatever.
Old 07-20-2014, 11:47 PM   #10
Miami.... Thanks for the explanation.... makes technical/practical sense, given impractical contracts or city regs.
Honest, I was going to suggest a battery powered light also....get rechargeable batteries....
EDIT: Costco has LED clip up battery lights right now with motion/ocupancy sensors for maybe 20 bucks.
Good luck....... Boy... is that the same Miami property with that cemented in big J-box collector.......
Old 07-21-2014, 12:35 AM   #11
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Maybe a silly question but I'll ask it. 240v lighting a possibility for this situation?
clw1963 is offline   Reply With Quote
Old 07-21-2014, 01:25 AM   #12
Muli volt ballast, for LED or fluorescent, but tapping into a dryer circuit makes things even more difficult if not a bigger code violation in itself.
I take it the laundry circuit from panel B also taps the light in unit B and A? When was the unit built? If that's the case you already have a 'technical' violation. In that case you really are better off just moving lamp A to washer plug A.
Worse come to worse you could ask your local AHJ (electrical inspector) to see if they will make an exception. But in all honesty I highly, highly doubt anyone will catch this or let alone be penalized for it.
I have to agree though, with the way tenant laws are written if it ever gets proven they are paying for a neighbor's 60 watt light (even if its a 7 watt LED), they do have the legal ground to sue for more than that light will ever draw Both rules sound insane, but that's the way our laws are written
Old 07-21-2014, 01:32 AM   #13
No everything in unit A and B are completely separated and done correctly except that single light in the utility room.
Built in 1955.
It is unusual for a duplex to have two separate utility rooms, each with it's own washer, dryer and hot water heater. Most of the time the two units share the same washer and dryer. Whoever originally built it must had intended for a real "mother in law" living next door.
Old 07-21-2014, 01:55 AM   #14
Built in 1955.
I mean if washer circuit B powers the laundry light in unit B that is no different than you putting lamp A on the A washer circuit.
The AHJ might actually let you do it. Worse come to worse, if someone give you a hard time you could just remove the pull chain lamp and install a plug in light with a pull chain and plug it into the washer outlet. The NEC has no control over what gets plugged in so technically it would neither be a violation, nor would unit B tenants pay for the other tenants lights.
Old 07-21-2014, 04:08 AM   #15
Mad Scientist
I wouldn't hesitate to put the light on the laundry recep. circuit. If I wanted to do it technically legal, I absolutely would provide a plug-in light of some sort like Jump-start said.
McSteve is offline   Reply With Quote
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 09:46 AM
Garage light circuit issue Uncle Ben Electrical 15 03-02-2012 02:00 PM
Arc fault light briefly lit when turning circuit back on... darthsmozers Electrical 26 01-16-2012 11:04 AM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
