Washer 3 Prong To Two Prong Old House 1940 - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 08:42 PM   #1
Rewards Points: 91
washer 3 prong to two prong old house 1940
Clothes Washer Label:
"Plug into a grounded 3-prong outlet. Do not use with an adapter. Do not use an extension cord. Do not remove the ground prong."
What to do? Ground 3rd to pipe, to ele box, or what should I do?
tks,
pa
paulmars is offline   Reply With Quote
Old 09-05-2013, 09:04 PM   #2
Rewards Points: 150
Either plug into a grounded outlet, if possible with out extension cord, rewire circuit and install grounded outlet, or install gfi. If I were you, the safest thing to do would be to rewire the circuit and install a grounded plug
romex1220 is offline   Reply With Quote
Old 09-05-2013, 09:43 PM   #3
seansy59's Avatar
Rewards Points: 258
Install a GFCI receptacle and label "No ground" if you cant run grounded wiring.
The ground is there to protect YOU! Not the machine.
If the GFCI senses an unbalance in load, (ie. machine shorts out) it will trip.
seansy59 is offline   Reply With Quote
The Following User Says Thank You to seansy59 For This Useful Post:
Speedy Petey (09-06-2013)
Old 09-05-2013, 09:48 PM   #4
MarginallyQualified
Rewards Points: 2,464
" Do not... Do not... Do not..."
What to do?
Ignore the lawyers.
Old 09-06-2013, 06:12 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
I wouldn't "rewire" anything. Just have a new circuit run for the washer.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Jim Port (09-06-2013)
Old 09-06-2013, 07:02 AM   #6
Rewards Points: 91
GFCI would be easy. Is that up to code?
pa
Old 09-06-2013, 04:28 PM   #7
MarginallyQualified
What code?
On point: what are you trying to accomplish?
Old 09-06-2013, 04:41 PM   #8
Rewards Points: 91
Originally Posted by TarheelTerp View Post
What code?
code for my county.
safety.
Old 09-06-2013, 08:35 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,920
pa
Yes, it is code compliant to replace the ungrounded receptacle with a GFCI labelled "no equipment ground". It is also pretty safe. I would not want a washer connected to an ungrounded circuit without a GFCI.
EDIT: 250.114 does not allow the use of this exception on a washer, because it specifically requires washers to be on grounded circuits. If you already had a GFCI there then it could be arguable since the house is older than 250.114, but if you have to modify the circuit to comply with code then the only legal solution would be to run a grounded circuit.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 09-06-2013, 08:49 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,152
Wouldn't it be best to just get an electricain to instal a ground on that circuit !
dmxtothemax is online now   Reply With Quote
Old 09-06-2013, 09:30 PM   #11
Licensed electrician
Rewards Points: 1,440
Article 250.114 requires that the washing machine be used on a grounded circuit. Installing a GFI would enhance safety, but would not meet the code or the instructions included with the washer.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
mpoulton (09-08-2013), stickboy1375 (09-07-2013)
Old 09-06-2013, 10:09 PM   #12
Rewards Points: 1,192
Best to run a new laundry circuit w/g.f.i. receptacle.
bobelectric is offline   Reply With Quote
Old 09-07-2013, 10:43 AM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This section is SOOOOOOO overlooked....
The Following 5 Users Say Thank You to stickboy1375 For This Useful Post:
frenchelectrican (09-07-2013), Jim Port (09-07-2013), Kyle_in_rure (09-07-2013), mpoulton (09-08-2013), Speedy Petey (09-07-2013)
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Questions about jacking up house to replace rotted rim/sill SolidStateS15 Remodeling 10 03-22-2010 11:43 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
