Warning Against Doing Dryer Outlet Generator Hookups - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-02-2012, 12:38 AM   #16
Originally Posted by frenchelectrican View Post
Not all the POCO will approve that type of transfer switch.
I was talking about a meter pan that came from the power company.
Hundred is offline   Reply With Quote
Old 11-02-2012, 12:43 AM   #17
" Euro " electrician
frenchelectrican's Avatar
I know what you mean on that one however with my POCO in Wisconsin do not provide the meter pan at all that something the customer have to buy it and they ( POCO ) will make a listing what it is approved and what not.
So again some POCO will provide the meter pan and some don't.
Note: WPS ( Wisconsin Pubic Service ) do not own the meter socket at all.
Simair to the Nxtel and WEngries plus couple other as well.
EDF ( French POCO ) do not provied the meter socket ( pan ) at all either.
Merci,
Marc
Old 11-02-2012, 12:53 AM   #18
I know, that's why my original post said "Some power companies offer a meter pan..."
Ummmmm, yeah. I don't know why you would argue this when I said the exact same thing
Old 11-02-2012, 12:56 AM   #19
Because I am in good mood to do this.,,
Merci,
Marc
Old 11-02-2012, 08:11 AM   #20
Rewards Points: 3,256
Some power companies offer a meter pan that has a transfer switch and inlet built right in. That is by far the best idea- clean installation, easy, safe, etc. Plug your generator right into the meter pan and throw the switch. It costs a couple hundred, but that is less than the typical interlock kit and inlet installation anyway.
Are these standard pans that can be purchased through a supply house? I will be needing a pan for a new service and this sounds like the perfect solution.
Could you please provide a manufacture or model so I can see if my POCO will approve it.....thanks!
zappa is offline   Reply With Quote
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
converting a 4 prong dryer outlet into a 3 prong dntbro1994 Electrical 8 07-02-2010 11:25 PM
Dryer outlet Davide Electrical 3 02-25-2009 12:48 PM
electric dryer - Chord and Outlet question? WILLIAM RIDGE Electrical 2 12-14-2008 10:45 PM
Running AC off of a Dryer Outlet TheCrow Electrical 7 06-16-2008 08:11 PM
