Warm GFCI Recepticle - Electrical - DIY Chatroom Home Improvement Forum
Old 04-03-2008, 09:21 PM   #1
cvp
warm GFCI recepticle
Is it normal for the ground fault circuit interrupter recepticles to feel warm and sometimes hot, then cool off, only to get warm or hot again.? This has been occuring while I have no major appliances plugged in, the lights are the only things using electricity on this circuit, and it seems to occur while I am at work during the day, when there is virtually no electricity being used
cvp is offline   Reply With Quote
Old 04-03-2008, 09:42 PM   #2
Electrician
If your at work how do you know its happening?
IMO, GFI's contain electronics, so they will probably feel warm to the touch.
chris75 is offline   Reply With Quote
Old 04-03-2008, 09:43 PM   #3
Power Gen/RS Engineer
Rewards Points: 566
Typically, no receptacle, be it GFCI or not should get hot. If this is the case, I would assume high-resistance connections at the recept.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-03-2008, 10:06 PM   #4
cvp
thank you. I know it is happening while I am at work since when I come home, they are hot or warm. I noticed it after I used my iron,plugged into a different receptacle and the GFCI became hot, not warm but hot.9 hours later the receptacle was still hot even though nothing was plugged into it. I am trying to learn as much as I can as I live in an expensive apartment complex and if this is not normal, I plan to ask the management to send over an electrician. So far they have sent over maintenance men, one who said the GFCI was wired improperly, so he fixed that but then put the GFCI back and I tested it after he left and it did not work, in fact neither worked. The next guy they sent, installed two new GFCI's, but then my light in another room did not work. So he came back and left a note, "sorry, loose wire. All fixed".
Old 04-03-2008, 10:09 PM   #5
Electrician
Hot is bad, so keep an eye on them and complain if the problem continues...
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
A few questions regarding GFCI AND AFCI protection CowboyAndy Electrical 5 03-10-2008 03:20 PM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 10:02 AM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
