Wardrobe Lighting Tips - Electrical - DIY Chatroom Home Improvement Forum
Old 09-27-2008, 11:08 PM   #1
Wardrobe lighting tips
My wife and I just went to ikea and spent alot of a PAX wardrobe with sliding doors. I would like some suggestions on fitting lights inside both wardrobes that come on only when the door is open please, I am unable to think of a good solution.
PC Pro, DIY Noob
wedge22 is offline   Reply With Quote
Old 09-27-2008, 11:16 PM   #2
What can I find here?
Winchester's Avatar
Rewards Points: 150
closet switches
Here's one example...
Winchester is offline   Reply With Quote
Old 09-27-2008, 11:18 PM   #3
And these are going to work well with a sliding door? Where would I buy these switches?
PC Pro, DIY Noob
Old 09-28-2008, 05:57 AM   #4
dSilanskas's Avatar
No you can't use that switch with a sliding door. Thats a door jam switch used only for doors that you pull or push open. Go to your local electrical store and you can buy a magnetic switch. To be totally honest with you I dont recall the name of it. But It is a two part switch you install one part on the door and the other part of the wardrob itself. When you open the door it breaks contact and sends power to the light. Same idea for a fridge. Just explain to them what you want to do and ask for a magnetic switch that can do that.
dSilanskas is offline   Reply With Quote
Old 09-28-2008, 10:08 AM   #5
Be aware that many magnetic switches for doors are designed for "low voltage" and "low amperage" security system use and would be dangerous to use if connected to house current.
Switches have "ratings" for the contacts. So be sure the switch can handle the load and is designed to be used with house current.
Also you could have a low voltage set-up with a low voltage transformer, low voltage security type switches on the door(s) and then use a "contactor" or "relay" to switch the lights on.
The low voltage switches would turn on the "contactor", then this in turn switches on the lights. The contactor contacts would be rated to handle the house current.
Billy_Bob is offline   Reply With Quote
Old 09-28-2008, 11:50 AM   #6
Electrician
Here is a perfect product for your application...
http://www.tequipment.net/RemconRC-120S.html
I sell these all the time and just use low voltage alarm magnets for the control wiring... You need Normally Closed type magnets for this to work correctly.
Here are the magnets I use...
chris75 is offline   Reply With Quote
Linking the 5amp lighting live to the 13amp neutral causes tripping of the rcb. Why? StevieV Electrical 8 08-24-2008 09:42 PM
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 02:36 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
