Wanting To Add A Circuit Breaker Subpanel To Fuse Panel. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2011, 06:23 AM   #1
Rewards Points: 152
Wanting to add a circuit breaker subpanel to fuse panel.
I want to add a circuit but have a full fuse panel, can i take out a 15A fuse, and install and 30A fuse and wire the subpanel to the 30A fuse and install to 15A circuits to the subpanel?
humberguy is offline   Reply With Quote
Old 06-24-2011, 07:31 AM   #2
That fuse panel has to be +40 yrs old, I think it is time to replace it, since buss and fuse connections deteriorate over time. And you may not have add a sub panel, but if it is for a different location, it will be much simpler with a new breaker panel.
Old 06-24-2011, 07:49 AM   #3
Rewards Points: 152
I'm planning on changing the panel in the future, i want to add the sub panel for the mean time. Can i do that by taking out a 15A fuse and installing a 30 fuse for a sub panel?
Old 06-24-2011, 09:15 AM   #4
joed's Avatar
Rewards Points: 12,030
A sub panel generally has a 240 volt feed. That will require two fuses to be used as the feed.
I don't see any problem with your plan other than two fuse are needed.
Old 06-24-2011, 10:08 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
While 120/240 volt sub panel are certainly the norm, I do not believe there is a specific prohibition against a 120 volt sub. If you proceed, I would plan on the ultimate use of this sub, and provide a panel and cabling (4 wire feeders with enough slack to move to new main panel) based on the ultimate use. Also insure the neutrals and grounds are kept separate in the sub.
Coastal South Carolina
Old 06-24-2011, 10:29 PM   #6
Rewards Points: 152
im thinking of getting this sub panel. The information says 1 phase sub panel, but looks like a 2 phase sub panel. Is it 1 phase or 2 phase sub panel?
http://www.homedepot.ca/webapp/wcs/s...&storeId=10051
Old 06-24-2011, 11:18 PM   #7
Missouri Bound's Avatar
A single phase panel has 2 hots and a neutral, the term "2 phase" is kind of confusing. Your picture shows a single phase panel. Two phase power generation is basically obsolete, but 2 phase is sometimes used for control circuits in 3 phase systems. At any rate, what comes to your home is single phase while some commercial power is 3 phase.
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 10:51 AM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 01:43 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Basic circuit breaker panel information ph3iron Electrical 4 02-08-2009 04:28 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
