Want To Wire Extra Lights To Garage Door Opener - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2008, 08:13 PM   #1
Want to wire extra lights to garage door opener
I'll try to make sense in what I say.
I want to have more lights turned on when I open the garage. Right now the only light that I get is from a small 40w bulb built into the garage door opener. That bulb is pretty dim.
I want to know if there is a way to hook up more lights to the unit so it will turn on when the garage opens and shuts off after a certain period of time just like the stock bulb on the opener.
SuperAkuma is offline   Reply With Quote
Old 07-31-2008, 08:24 PM   #2
You could the manu how much extra current the relay that turns on the bulb can handle.
If you can read the numbers off the relay case inside the unit [cut the power first] the relay contact specs can probably be found on the Internet and that will tell how many more lamps you can use.
You can use the bulb socket to drive the 120v coil of another [$4 or so] relay and get very high current handling capacity.
How many more bulbs, flourescent or incandescent or LED, do you want to use?
Old 07-31-2008, 08:45 PM   #3
I was thinking of a fluorescent tube type that hangs from the ceiling.
Old 07-31-2008, 09:03 PM   #4
Rewards Points: 506
Send a message via AIM to theatretch85
I would say the external relay route would probably be best. I know I've seen 120volt coil relays at the local Ax-Man that have a contact rating of 15amps (which would be more than enough for a few fluorescent lights). I would wire up the relay in a junction box in the ceiling above the garage door opener and then run a cord down to the garage door opener and plug it into the lamp socket. Though I am sure if you had an inspector look at he'd red flag it, even if everything was wired up correctly. Its do-able and for pretty cheap too, the relay being the only additional part you'd have to find and purchase.
theatretch85 is offline   Reply With Quote
Old 07-31-2008, 09:18 PM   #5
Even less intrusive would be to use a "Adaptor, lamp holder to outlet", Servistar AR125 that goes from a lamp socket to a two prong outlet, then you plug the flourescent fixture into the socket.
You'd also need a grounding adaptor and short ground wire to pick up a ground for the flourescent fixture.
http://images.google.com/imgres?imgu...%3D2%26hl%3Den
I'm not sure at what point an installation of this type becomes no more than a lamp plugged into a socket, and when it becomes something that's regulated by the NEC.
And, is a garage a "damp location" or a "dry indoor location"?
Old 08-01-2008, 12:09 AM   #6
I would say dry location.
theatretch85, what kind of rely are you talking about? Can you give me a link? I never really seen a rely for a house(not that I looked before). I work a lot on car audio and security, so I understand the need for a rely. I just never saw one used for a house.
Old 08-01-2008, 04:10 AM   #7
Rewards Points: 150
Rather than mess with relays this company has these motion sensors that activate a light control. I would call them up and tell them what you want to do and they will recomend a wireless solution. Plug and play stuff. http://www.x10.com/automation/index.html#motion_sensors
James Con is offline   Reply With Quote
Old 08-01-2008, 08:01 AM   #8
Rewards Points: 506
The particular relay I have here has the 120volt coil (so no ac adaptor needed) and the relay contacts are rated for 15 amps. I don't know who makes it but I bought it at Ax-Man in minneapolis, mn. If you are looking for relays, take a look at www.newark.com thats where I buy most of my electronic parts (led's, resistors, PCB mounted relays, etc).
I actually have a relay wired to the back of my light switch in my room, its a 3 way dimmer switch and I wired the relay to the "other" terminal and the common. So when the light is "off" its actually on the relay contacts waiting for the relay to actuate. On this particular relay it requires a 12VDC input so I wired it to an adaptor and plugged it into a timer. So now my lights turn on in the morning to wake me up (in addition to my computer playing music).
Old 08-01-2008, 09:10 AM   #9
Try www.Hosfelt.com. Great price/performance ratios.
Old 08-01-2008, 06:08 PM   #10
Ash
Send a message via MSN to Ash
Most small contactors (relays) are quite capable. They can handle for sure a 36 W fluorescent without an additional downstream contactor
The problem is the inrush current of a fluorescent fixture. There is a power factor correction capacitor inside which makes an arc when the circuit closes. To avoid this remove the capacitor. You may connect it somewhere else permanently (it will not harm) if it is required for some reason
In some fixtures the capacitor is reuired for the fixture to work. Dont use them here (in other places do - Some of them are better than the standard fixture)
If you use an external relay you may use whatever lights you want
Ash is offline   Reply With Quote
Old 08-01-2008, 08:39 PM   #11
Electrician
Lets try the easy way... Buy yourself an occupancy sensor wall switch and be done with it...
chris75 is offline   Reply With Quote
Old 08-01-2008, 08:43 PM   #12
I think I will do that.
I never really used one of these before. Can it sense a car coming in from about 15-20 feet away or the garage door opening?
You are talking about this right?
http://www.homedepot.com/webapp/wcs/...ctId=100396703
Old 08-01-2008, 08:53 PM   #13
Electrician
My garage door opening/closing sets the sensor off...
Old 08-02-2008, 12:18 AM   #14
Idiot Emeritus
Rewards Points: 1,492
Even better, if aimed right, it'll sense a person walking into a dark garage, and turn the lights on (hopefully before said person trips over something...).
Rob
micromind is offline   Reply With Quote
Old 08-02-2008, 08:48 AM   #15
Electrician
Rob
These are fixed sensors, they dont get aimed.
Installing Pot Lights - 12AWG and 14/2 wire ... help! njchan Electrical 4 04-10-2008 07:50 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Garage Lights Git Electrical 9 03-20-2008 09:35 PM
Lights for a garage? stagger19 Electrical 8 01-16-2007 06:58 AM
garage lights kelr Electrical 1 06-20-2005 11:31 PM
