Old 08-04-2012, 08:10 PM   #1
Arrow
Want to replace thermostat but . . .
I have radiant ceiling heat. The thermostat has two black wires (load) and two red wires (line). It is an old RA=STAT model.
The easy question first...What type of PROGRAMMABLE thermostat could I replace this with?
The hard question. I can turn OFF the breakers in the electric panel but I still get an electrical voltage at the thermostat. (I just had a new electric panel and all new breakers installed and it appears to be doing the same thing the old Federal Pacific did - which is to HEAT the room - even with the breakers OFF!)
This can NOT be right can it???
Papa Smoke is offline   Reply With Quote
Old 08-04-2012, 08:25 PM   #2
E2 Electrician
stickboy1375's Avatar
These would work... http://www.pexuniverse.com/honeywell...ro-thermostats
Check out the 8000 series.
If you turn off the breakers and still have voltage at the t-stat, then you either didnt turn off the correct breaker, or something is amiss with the wiring and needs to be investigated....
stickboy1375 is online now   Reply With Quote
Old 08-04-2012, 08:38 PM   #3
Missouri Bound's Avatar
Was the new panel labeled when installed? If not, have the "installer" come back and do it, if it was labeled have him come back and do it RIGHT. Something is amiss alright. Glad you got rid of the FP panel anyway. Any chance you have a sub panel somewhere for just the radiant heat?
Do you want it your way or the right way?
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
Replace 3 wire electric baseboard thermostat Bhurl5 HVAC 4 11-27-2011 09:07 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 06:28 PM
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 01:52 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
