Want To Put In A New Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2006, 10:05 AM   #1
Want to put in a new circuit
I re routed the 14 3 wire that was going thru my master bedroom wall
studs to make room for a door. Now my new thing, just go a window AC
that needs a dedicated outlet, i know how to put in the outlet box, an
connect the black wire, white wire, ground wire from a 14 2 cable, but
need a web site that shows how to put in a 15 AMP circuit breaker box,
in the breaker panel box. I now you shut down the main power, put wire
nuts on the cable going in, but connecting the -hot-nuetral-an ground wire- in the bars i need pictures, the 15 AMP breaker you just push in, i
have 2 spots open on my panel.:confused:
pwallyp is offline   Reply With Quote
Old 05-27-2006, 11:18 AM   #2
Sciencerules
MAS2006's Avatar
Safety
From the wording of your question you need to minimally do some more research to be safe. Parts of Service panel still hot with main off, call licensed electrician. Do you know if you need a permit/inspection for this worK? :confused:
MAS2006 is offline   Reply With Quote
Old 05-27-2006, 11:59 AM   #3
Yes, i know that when you shut of the main breaker you just stop the
juice going into the house. The wires going to that main are still live. All
i'm asking for is for help finding a web-site. I'm not perfect but i will stay
away from the wires comeing into the house, i don't want to get electcuited. Thanks for your help.
Old 05-27-2006, 12:28 PM   #4
Originally Posted by pwallyp
but need a web site that shows how to put in a 15 AMP circuit breaker box, in the breaker panel box. I now you shut down the main power, put wire nuts on the cable going in, :confused:
Your wording here suggests to me that you are not familiar with how to do wiring in a panel. First the breaker is not called a breaker box. Second there are few reasons to put wire nuts in a panel.
Electrical panels are not safe places to be. If you are not 100 percent sure of what you are doing then you need to hire someone who is.
Somone with less scruples may chime in, but I for one will not give you just enought information to get hurt.
jwhite is offline   Reply With Quote
Old 05-27-2006, 01:18 PM   #5
I guess I am that person. Buy your breaker, make sure it is the right type for your panel. On the back of the breaker there is a hook on one edge and metal clip on the other, obviously the metal part is where it recieves its power from the live bussing running down the center of your panel. Look at it real good and get understanding of how it is going to snap in, *this is not a time for trial and error*. After the breaker is snapped follow the example you already see in your panel as far where everyhting goes and how it should all look. First do your ground wire, then the neutral and lastly after making sure your new breaker is off hook up your hot wire. If your still not real clear then call an electrician, the cheapest one you can find should be able to simply hook up the wires correctly, and would enjoy the quick 50 bucks(at most)
Remember that getting shocked is not your biggest worry while in a panel, but more so if you accidentally cause a short while in there you WILL receive very severe burns, possibly blow out your ear drums and even get catarax some 3 years later.
Sparky Joe is offline   Reply With Quote
Old 05-27-2006, 03:27 PM   #6
Yes you are.
Old 05-28-2006, 01:37 PM   #7
Hey when I first worked in a live panel for work I had even less experience than this guy. As long as he realizes it's dangerous he'll do fine.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Loose electrical outlets travishume Electrical 30 08-01-2008 07:21 PM
Circuit configuration??? Clutchcargo Electrical 11 05-30-2007 08:01 AM
Conflicting Circuit Info!?? BenBil Electrical 9 01-15-2007 08:26 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
