Want To Measure Some AMPS ... - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 11:59 PM   #1
Rewards Points: 83
Want to measure some AMPS ...
Howdy all,
We are slightly Christmas-decoration-crazy in my family. The living room gets the Winter Wonderland treatment, complete with enough bulbs that you don't need heat.
I want to measure the amps all those lights are putting on the circuit. (20 amp, 12 gauge) While we aren't throwing the breaker, I am confident we are close to the capacity, and am wondering if the living room should be divided into two circuits.
I think what I want is a clamp meter to do this, correct? I'm not going to be a professional electrician, so I don't see the need for the high end, but I also detest buying junk.
Any recommendations for a modestly priced meter that isn't junk? I also understand most (all?) are also usable as regular multimeters? One of those is missing from my toolkit as well.
Thanks,
Jim
simanco is offline   Reply With Quote
Old 06-26-2012, 12:07 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by simanco View Post
Howdy all,
Thanks,
Jim
Ideal or Klein have some reasonably priced units. Try Amazon, Lowes, Sears, or Home Depot.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-26-2012, 12:08 AM   #3
Rewards Points: 264
If everything you want to measure is plug in, you could use something like this:
http://www.amazon.com/P3-Internation.../dp/B00009MDBU
Now you'll have to get a multi-meter separately. However, the MM functions I've seen in the clamp on meters didn't seem to be nearly as inclusive as the options on a cheap $15 multimeter.
a_lost_shadow is offline   Reply With Quote
The Following 2 Users Say Thank You to a_lost_shadow For This Useful Post:
ddawg16 (06-26-2012), electures (06-26-2012)
Old 06-26-2012, 12:48 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
The above is pretty solid advice. Those Kill O Watt units are a good value for the average home owner who does not have a clamp on amp probe in his pocket.
They have several advantages...
Safe
Easy to use
And fairly accurate since they are designed for the low end amps. My clamp on meter is good for about 400A....I doubt the average home owner is going to need that much range.
Old 06-26-2012, 09:41 AM   #5
Rewards Points: 826
I did this a few years ago with all the Christmas lights as I was curious what my electric bill would uptick for the season. The device above is great and inexpensive. Gives you watt hours as well so you can compute electric bill easily. Also for irregular loads like computers, set top boxes, or a window AC you can run for 24 hours or a week to get an average reading.
I learned Christmas lights outside cost me $34.62 for the season and indoor $26.53 or $61.15 for both..... I concluded it was the cheapest part of the holiday....
curiousB is offline   Reply With Quote
Old 06-26-2012, 09:50 AM   #6
JOATMON
ddawg16's Avatar
Boy, is that not the truth.....you don't want to see our wine bill......
Old 06-26-2012, 06:01 PM   #7
Rewards Points: 83
Thanks all! I should have thought of the Kill-A-Watt ... I own one. <sigh>
Jim
Old 06-26-2012, 07:47 PM   #8
Knucklez's Avatar
Rewards Points: 932
i remember the good ole' days.. dad would string up the tree plug it in to blaze the tree in to holiday glory. and whoa to you if you touched a light bulb, 2nd degree burn instantly.
yep.. you didn't care to measure anything.
anyway, just wanted to remind you that electrical considers 80% loaded as "max", so your 20A circuit can only run continuously 20*0.8 = 16A
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 06-26-2012, 11:34 PM   #9
Rewards Points: 83
Do I understand correctly that "continuously" equates to 3+ hours? In other words, if everything is on for 3 or more hours and everything is 16 or more amps I have a problem?
Jim
Old 06-27-2012, 12:28 AM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,938
Residential lighting loads are defined as non-continuous. The 80% rule doesn't apply to just any random thing that someone thinks is "continuous". A "continuous load" is a term of art defined by the NEC, and generally includes things that are expected to operate for more than 3 hours without any interruption, but has specific inclusions and exceptions. The base assumption is that a 20A circuit is good for 20A. The 80% derating is an exception to that under specific circumstances.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
jbfan (06-27-2012)
Measure Amps jamiedolan Electrical 13 01-17-2009 11:06 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 08:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 07:13 PM
